Saltar al contenido principal
CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement
Qué necesitas
  1. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement, Power Cord: paso 1, imagen 1 de 1
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: paso 2, imagen 1 de 1
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: paso 3, imagen 1 de 2 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: paso 3, imagen 2 de 2
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: paso 4, imagen 1 de 2 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: paso 4, imagen 2 de 2
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: paso 5, imagen 1 de 3 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: paso 5, imagen 2 de 3 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: paso 5, imagen 3 de 3
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement, Temperature Control Switch: paso 6, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the screws on both sides of the temperature control switch.
    • Pop out the control switch.
Conclusión
Annalise White
Miembro Desde 10/26/22
530 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 2-7, Petersen Fall 2022 Miembro de UMass Dartmouth, Team 2-7, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G7
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 260
