Introducción
Algunos de los controladores Joy-Con restantes del primer lote de Nintendo son conocidos por problemas de sincronización. Esto se debe a un defecto de diseño menor y se puede remediar con un pequeño trozo de espuma conductora que a menudo se encuentra en envases viejos alrededor de la casa.
Qué necesitas
Instrucciones de Vídeo
Para volver a ensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
12 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ Francisco Javier Saiz Esteban nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
7Guía Comentarios
What thickness of conductive foam should I choose? There are 3 sizes: 3mm/0.12, 5mm/0.20", 10mm/0.39"
maximaleks - Contestar Compartir
The space is ~9 mm wide, so I would go with the 10 mm size and you can trim it down if you need to!
Taylor Dixon - Contestar Compartir
I've got the same problem but with the right joycon but I don't know where the wireless card is, please help
Nathan Currie - Contestar Compartir
Hello I opened up my left joycon and saw conductive foam inside already! I replaced it with one that I bought on amazon (I made sure it was actually conductive foam). But it still won’t sync. Any ideas? Could it be that little solder bubble that connects to the antenna has gone bad? Should I try to reflow it? I also checked to see if any capacitors in the top of the board were shorted and none of them were. If you have any ideas I would be happy to hear!
Chaim Bendahan - Contestar Compartir
I opened my left Joycon and found that there is no antenna area near the joystick compartment. It’s just an empty space what should I do, I have the conductive foam but obviously don’t know where to place.
Omar Gonzalez - Contestar Compartir
