Saltar al contenido principal
Braun KMM1 Coffe Grinder Disassembly for cleaning
Qué necesitas
  1. Braun KMM1 Coffe Grinder Disassembly for cleaning, Braun KMM1 Coffe Grinder Disassembly for cleaning: paso 1, imagen 1 de 1
    • First, remove the coffee powder container
  2. Braun KMM1 Coffe Grinder Disassembly for cleaning: paso 2, imagen 1 de 1
    • Remove the cap of the bean container
  3. Braun KMM1 Coffe Grinder Disassembly for cleaning: paso 3, imagen 1 de 2 Braun KMM1 Coffe Grinder Disassembly for cleaning: paso 3, imagen 2 de 2
    • Now it's time to rotate the bean container anti-clockwise to remove it from the machine
  4. Braun KMM1 Coffe Grinder Disassembly for cleaning: paso 4, imagen 1 de 1
    • Here you can see the mill wheel which is now ready to be cleaned
  5. Braun KMM1 Coffe Grinder Disassembly for cleaning: paso 5, imagen 1 de 3 Braun KMM1 Coffe Grinder Disassembly for cleaning: paso 5, imagen 2 de 3 Braun KMM1 Coffe Grinder Disassembly for cleaning: paso 5, imagen 3 de 3
    • Back to the bean container!
    • After a short cleaning action you should be able to loosen this three Philips screws
  6. Braun KMM1 Coffe Grinder Disassembly for cleaning: paso 6, imagen 1 de 2 Braun KMM1 Coffe Grinder Disassembly for cleaning: paso 6, imagen 2 de 2
    • Now the bean container is completely disassembled and ready for some cleaning work!
Conclusión
16 personas más completaron esta guía.
Daniel
Miembro Desde 07/06/15
934 Reputación
2 Guías creadas
Equipo
iFixit EU Team Miembro de iFixit EU Team
Staff
44 Miembros
1,110 Guías creadas
9 comentarios
Hi Daniel,
Thanks for the tutorial.
Would you have, by any chance, the usermanual of the grinder?
I’m wondering to what grinding size the numbering is corresponding to.
Many thanks! :)
Best regards,
Greg
freestyle_on_the_moon - Contestar
I have this same issue! Did you ever find out? Im guessing that the grind size of the KMM1 is the same as the KMM20? So left (where it says mocca)for finest grind, right for the largest grind?
Will Clempson -
Umm.. My bottom burr doesn’t seem to have screws and look like rivits. maybe previous owner stripped the screws :(
Zarni Ko - Contestar
Mine has something like rivets as well. I used toothpicks and cotton swabs to clean as much as I could,, then had some luck running dried couscous through the grinder. Softer than rice and seemed to pick up the last bits of residue.
Zeke Kossover -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 25
Ultimos 30 días: 137
Todo El Tiempo: 10,940
