Saltar al contenido principal
Blu Grand M Camera Replacement
Qué necesitas
  1. Blu Grand M Camera Replacement, Battery: paso 1, imagen 1 de 2 Blu Grand M Camera Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the two plastic plates with a plastic opening tool.
  2. Blu Grand M Camera Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
  3. Blu Grand M Camera Replacement: paso 3, imagen 1 de 3 Blu Grand M Camera Replacement: paso 3, imagen 2 de 3 Blu Grand M Camera Replacement: paso 3, imagen 3 de 3
    • Remove SIM card tray with paperclip or SIM card tray removal tool.
    • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
  4. Blu Grand M Camera Replacement: paso 4, imagen 1 de 2 Blu Grand M Camera Replacement: paso 4, imagen 2 de 2
    • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
    • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
  5. Blu Grand M Camera Replacement, Plastic Plate: paso 5, imagen 1 de 2 Blu Grand M Camera Replacement, Plastic Plate: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the yellow plastic tape using a pair of tweezers.
  6. Blu Grand M Camera Replacement: paso 6, imagen 1 de 3 Blu Grand M Camera Replacement: paso 6, imagen 2 de 3 Blu Grand M Camera Replacement: paso 6, imagen 3 de 3
    • Use a Phillips #000 screwdriver to remove two black 4.0mm screws.
    • Use a Phillips #000 screwdriver to remove 2 silver 4.0mm screws
    • Remove the plastic cover along the top by tugging on it on the corner as shown.
  7. Blu Grand M Camera Replacement, Camera: paso 7, imagen 1 de 2 Blu Grand M Camera Replacement, Camera: paso 7, imagen 2 de 2
    • Use the plastic opening tool to lift the camera out.
Conclusión
Kristen Gismondi
Miembro Desde 11/12/14
82,296 Reputación
200 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,299 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 140
