Saltar al contenido principal
Blu Dash 5.0 Dual SIM Charging Port Replacement
Qué necesitas
  1. Blu Dash 5.0 Dual SIM Charging Port Replacement, Battery: paso 1, imagen 1 de 1
    • Find the small slot on the bottom left corner of the back panel.
    • Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
    • When the back panel is loose enough, use your fingers to remove it completely.
  2. Blu Dash 5.0 Dual SIM Charging Port Replacement: paso 2, imagen 1 de 1
    • With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
  3. Blu Dash 5.0 Dual SIM Charging Port Replacement, Display Cable: paso 3, imagen 1 de 1
    • Using the PH00 Phillips head screwdriver unscrew the screws holding the panel down, making sure to keep track of the position of the screws.
    • The screw holes with the red circle around them hold screws with a 3.5 mm length.
    • The screw holes with the orange circle around them hold screws with a 2.5 mm length.
  4. Blu Dash 5.0 Dual SIM Charging Port Replacement: paso 4, imagen 1 de 2 Blu Dash 5.0 Dual SIM Charging Port Replacement: paso 4, imagen 2 de 2
    • Insert the plastic opening tool into a corner of the plastic panel and gently pry it away from the rest of the phone.
    • Do this for each corner until the panel pops up.
  5. Blu Dash 5.0 Dual SIM Charging Port Replacement: paso 5, imagen 1 de 3 Blu Dash 5.0 Dual SIM Charging Port Replacement: paso 5, imagen 2 de 3 Blu Dash 5.0 Dual SIM Charging Port Replacement: paso 5, imagen 3 de 3
    • Along the right side of the phone you will see a long black wire with 2 gold end pieces on the end. This is the display cable.
    • To disconnect the gold end pieces from the motherboard, take the tweezers and gently but firmly pull upwards. Do this for both ends and the wire will disconnect.
  6. Blu Dash 5.0 Dual SIM Charging Port Replacement, Motherboard: paso 6, imagen 1 de 3 Blu Dash 5.0 Dual SIM Charging Port Replacement, Motherboard: paso 6, imagen 2 de 3 Blu Dash 5.0 Dual SIM Charging Port Replacement, Motherboard: paso 6, imagen 3 de 3
    • Using the tweezers, lift the tabs where the cables are connected, this unlocks the cables. The cables will slide out of sockets easily when they are unlocked. Pull from wire using tweezers as pictured.
    • The red rectangles represent where the cable's are located.
    • The orange rectangles are where the cables pug into the ports. This is where you want to apply the tweezers.
    • There are two black tabs and one blue tab.
  7. Blu Dash 5.0 Dual SIM Charging Port Replacement, Charging Port: paso 7, imagen 1 de 1
    • Solder the pins on the back of the charging port. Here's a guide to soldering: How to solder
    • Soldering iron can be very hot!
  8. Blu Dash 5.0 Dual SIM Charging Port Replacement: paso 8, imagen 1 de 2 Blu Dash 5.0 Dual SIM Charging Port Replacement: paso 8, imagen 2 de 2
    • Pry charging port away from the board using the metal spudger.
    • It's easier to pry with the metal spudger inserted in the charging port.
Conclusión
Una persona más ha completado esta guía.
Jack Manley
Miembro Desde 01/30/17
114 Reputación
1 Guía escrita
Equipo
IUPUI, Team 1-1, Baechle Spring 2017 Miembro de IUPUI, Team 1-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G1
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 514
