Saltar al contenido principal
Blink Video Doorbell LED Light Replacement
Qué necesitas
  1. Blink Video Doorbell LED Light Replacement, Battery: paso 1, imagen 1 de 3 Blink Video Doorbell LED Light Replacement, Battery: paso 1, imagen 2 de 3 Blink Video Doorbell LED Light Replacement, Battery: paso 1, imagen 3 de 3
    • Push the opening key into the small opening with the two gray buttons on the bottom of the device.
    • The device will click off the mount.
    • Push the device up from the mount and slide it off.
  2. Blink Video Doorbell LED Light Replacement: paso 2, imagen 1 de 3 Blink Video Doorbell LED Light Replacement: paso 2, imagen 2 de 3 Blink Video Doorbell LED Light Replacement: paso 2, imagen 3 de 3
    • Use your finger to slide the gray tab, located near the bottom of the device, upwards.
    • Remove the battery cover.
  3. Blink Video Doorbell LED Light Replacement: paso 3, imagen 1 de 3 Blink Video Doorbell LED Light Replacement: paso 3, imagen 2 de 3 Blink Video Doorbell LED Light Replacement: paso 3, imagen 3 de 3
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
    • Do not mix used and new batteries or batteries of different types (for example, lithium and alkaline batteries).
  4. Blink Video Doorbell LED Light Replacement, Back Panel: paso 4, imagen 1 de 3 Blink Video Doorbell LED Light Replacement, Back Panel: paso 4, imagen 2 de 3 Blink Video Doorbell LED Light Replacement, Back Panel: paso 4, imagen 3 de 3
    • Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
    • Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
    • Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
  5. Blink Video Doorbell LED Light Replacement, LED Light: paso 5, imagen 1 de 3 Blink Video Doorbell LED Light Replacement, LED Light: paso 5, imagen 2 de 3 Blink Video Doorbell LED Light Replacement, LED Light: paso 5, imagen 3 de 3
    • Remove the three 6 mm screws from the upper part of the motherboard using a JIS #1 screwdriver.
    • Use an opening tool to release the motherboard from the device.
  6. Blink Video Doorbell LED Light Replacement: paso 6, imagen 1 de 3 Blink Video Doorbell LED Light Replacement: paso 6, imagen 2 de 3 Blink Video Doorbell LED Light Replacement: paso 6, imagen 3 de 3
    • Use a soldering iron to desolder the LED connections from the motherboard.
Conclusión
Kayla Crai
Miembro Desde 10/18/24
495 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 1-1, Konn Fall 2024 Miembro de UMass Dartmouth, Team 1-1, Konn Fall 2024
UMASSD-KONN-F24S1G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 17
Ultimos 30 días: 22
Todo El Tiempo: 81
