Saltar al contenido principal
BlackBerry Z30 Middle Frame Replacement
Qué necesitas
  1. BlackBerry Z30 Middle Frame Replacement, Battery cover: paso 1, imagen 1 de 1
    • Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
  2. BlackBerry Z30 Middle Frame Replacement, Remove SIM and Media Card: paso 2, imagen 1 de 1
    • Remove the SIM card and the Media SD card by pushing on them.
  3. BlackBerry Z30 Middle Frame Replacement, Unscrewing the LCD panel: paso 3, imagen 1 de 3 BlackBerry Z30 Middle Frame Replacement, Unscrewing the LCD panel: paso 3, imagen 2 de 3 BlackBerry Z30 Middle Frame Replacement, Unscrewing the LCD panel: paso 3, imagen 3 de 3
    • Locate and unscrew all 10 T5 screws around the back cover
  4. BlackBerry Z30 Middle Frame Replacement, Separate the LCD from the Frame: paso 4, imagen 1 de 2 BlackBerry Z30 Middle Frame Replacement, Separate the LCD from the Frame: paso 4, imagen 2 de 2
    • Use Plastic opening tools to separate the LCD from the Main body
    • Do NOT remove the screen yet, it is attached with a very fragile ribbon to the main board.
    • Start on the same side of the Audio Jack
  5. BlackBerry Z30 Middle Frame Replacement, Remove the LCD: paso 5, imagen 1 de 2 BlackBerry Z30 Middle Frame Replacement, Remove the LCD: paso 5, imagen 2 de 2
    • Use a plastic tool to carefully switch up the LCD ribbon holder
    • Detach the LCD from the main board
    • When installing the new LCD, make sure the ribbon is inserted to the white line.
  6. BlackBerry Z30 Middle Frame Replacement, LCD Panel removal: paso 6, imagen 1 de 1
    • You can now detach the LCD Panel from the main frame.
  7. BlackBerry Z30 Middle Frame Replacement, Untie the System board: paso 7, imagen 1 de 1
    • With a plastic tool, untie the system board by detaching the ribbons attached to it
    • The battery ribbon is on the bottom right
    • Be gentle when detaching these Ribbons as they are very easy to tear and damage.
  8. BlackBerry Z30 Middle Frame Replacement, Untie the System board Part 2: paso 8, imagen 1 de 1
    • Be gentle as any other system board ribbons, they are very easy to damage
  9. BlackBerry Z30 Middle Frame Replacement, Untie the system board Part 3: paso 9, imagen 1 de 1
    • Power Button /Audio Jack
    • Flash
    • Rear Facing Camera
  10. BlackBerry Z30 Middle Frame Replacement, System board removal: paso 10, imagen 1 de 1
    • Once all Ribbons untied, gently wiggle the system board out of the frame
    • Do not pull hard as there might be a ribbon on the way
  11. BlackBerry Z30 Middle Frame Replacement, Remove the Rear Camera: paso 11, imagen 1 de 2 BlackBerry Z30 Middle Frame Replacement, Remove the Rear Camera: paso 11, imagen 2 de 2
    • Use a pair of pliers to remove the rear facing camera
  12. BlackBerry Z30 Middle Frame Replacement, Remove the Battery: paso 12, imagen 1 de 3 BlackBerry Z30 Middle Frame Replacement, Remove the Battery: paso 12, imagen 2 de 3 BlackBerry Z30 Middle Frame Replacement, Remove the Battery: paso 12, imagen 3 de 3
    • If this is the original battery, it might be hold down by VERY strong adhesive on the top, middle and bottom part. Be careful not to damage the battery
    • As pointed in the comments, be careful about the NFC membrane when removing the battery. Use heat to loosen the glue.
  13. BlackBerry Z30 Middle Frame Replacement, Replace the Middle Frame: paso 13, imagen 1 de 1
    • Re-Assemble the unit using the new middle frame.
Conclusión
4 personas más completaron esta guía.
Hans
Miembro Desde 10/20/14
1,920 Reputación
6 Guías creadas
Equipo
Mero IT Services Miembro de Mero IT Services
Business
1 Miembro
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 3,822
