Saltar al contenido principal
BlackBerry Z30 Display Assembly Replacement
Qué necesitas
  1. BlackBerry Z30 Display Assembly Replacement, Battery cover: paso 1, imagen 1 de 1
    • Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
  2. BlackBerry Z30 Display Assembly Replacement, Remove SIM and Media Card: paso 2, imagen 1 de 1
    • Remove the SIM card and the Media SD card by pushing on them.
  3. BlackBerry Z30 Display Assembly Replacement, Unscrewing the LCD panel: paso 3, imagen 1 de 3 BlackBerry Z30 Display Assembly Replacement, Unscrewing the LCD panel: paso 3, imagen 2 de 3 BlackBerry Z30 Display Assembly Replacement, Unscrewing the LCD panel: paso 3, imagen 3 de 3
    • Locate and unscrew all 10 T5 screws around the back cover
  4. BlackBerry Z30 Display Assembly Replacement, Separate the LCD from the Frame: paso 4, imagen 1 de 2 BlackBerry Z30 Display Assembly Replacement, Separate the LCD from the Frame: paso 4, imagen 2 de 2
    • Use Plastic opening tools to separate the LCD from the Main body
    • Do NOT remove the screen yet, it is attached with a very fragile ribbon to the main board.
    • Start on the same side of the Audio Jack
  5. BlackBerry Z30 Display Assembly Replacement, Remove the LCD: paso 5, imagen 1 de 2 BlackBerry Z30 Display Assembly Replacement, Remove the LCD: paso 5, imagen 2 de 2
    • Use a plastic tool to carefully switch up the LCD ribbon holder
    • Detach the LCD from the main board
    • When installing the new LCD, make sure the ribbon is inserted to the white line.
  6. BlackBerry Z30 Display Assembly Replacement, LCD Panel removal: paso 6, imagen 1 de 1
    • You can now detach the LCD Panel from the main frame.
Conclusión
10 personas más completaron esta guía.
Hans
Miembro Desde 10/20/14
1,926 Reputación
6 Guías creadas
Equipo
Mero IT Services Miembro de Mero IT Services
Business
1 Miembro
6 Guías creadas
6 comentarios
This YouTube video by ItsmeJC also helped a lot.
https://www.youtube.com/watch?v=yISRs3lW...
I had difficulties when trying to re-insert and re-lock the ribbon in place, but it turned out that I overlooked and missed the fact that the ribbon should go under the ribbon holder, not between it and the "fixing switch". Otherwise, the procedure was a snap.
Syafiq Saidan - Contestar
After screen replacement I'm having proximity sensor issues. screen is responsive and everything works good but its flashing on and off. disconnecting the proximity sensor fixes the issue but it's also the same connection as lock button so not an option. reinstalling original screen works as normal, new screen is original manufacture and has the same foam gaskets and uv filters as original around the prox sensor...
any thoughts?
Andrew - Contestar
Hi Andrew,
Beware, some sellers claims their screens are original but they are not. The few times the issue you have discribed occured to me where when the LCD unit was defective. Please arrange an exchange with your seller if you can. The fact that when you put back your shattered screen and it works is the proof that your new unit is defective.
Good luck.
Hans -
Pricing for the BlackBerry Z 30 screen? As well as the availability?
Nelson lima - Contestar
Are black berry screens available in Uganda
mwaka marcus -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 12,873
