Saltar al contenido principal
Black and Decker CM0700BZ Lid Replacement
Qué necesitas
  1. Black and Decker CM0700BZ Lid Replacement, Lid: paso 1, imagen 1 de 2 Black and Decker CM0700BZ Lid Replacement, Lid: paso 1, imagen 2 de 2
    • Open the lid of the coffee maker.
    • Remove the brew cup.
  2. Black and Decker CM0700BZ Lid Replacement: paso 2, imagen 1 de 3 Black and Decker CM0700BZ Lid Replacement: paso 2, imagen 2 de 3 Black and Decker CM0700BZ Lid Replacement: paso 2, imagen 3 de 3
    • Place your finger, screwdriver, or spudger behind the corner of the tab.
    • Pull up on the tab until it disconnects from the coffee maker.
  3. Black and Decker CM0700BZ Lid Replacement: paso 3, imagen 1 de 3 Black and Decker CM0700BZ Lid Replacement: paso 3, imagen 2 de 3 Black and Decker CM0700BZ Lid Replacement: paso 3, imagen 3 de 3
    • Hold the tab while pushing back on the lid.
    • The lid should open fully with the top of the lid facing down.
  4. Black and Decker CM0700BZ Lid Replacement: paso 4, imagen 1 de 2 Black and Decker CM0700BZ Lid Replacement: paso 4, imagen 2 de 2
    • Insert the flathead screwdriver or spudger into one of the inserts holding the lid.
    • Pry facing away from the lid to force the peg out.
    • You should hear a pop when it disconnects.
    • Hold the lid and pull it away from the other insert.
  5. Black and Decker CM0700BZ Lid Replacement: paso 5, imagen 1 de 1
    • To also remove the shower head, use the Shower Head guide.
Conclusión
Shawn Robichaud
Miembro Desde 10/26/22
729 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 279
