Saltar al contenido principal
Black and Decker CM0700BZ Shower Head Replacement
Qué necesitas
  1. Black and Decker CM0700BZ Shower Head Replacement, Shower Head: paso 1, imagen 1 de 2 Black and Decker CM0700BZ Shower Head Replacement, Shower Head: paso 1, imagen 2 de 2
    • Open the lid of the coffee maker.
    • Remove the brew cup.
  2. Black and Decker CM0700BZ Shower Head Replacement: paso 2, imagen 1 de 3 Black and Decker CM0700BZ Shower Head Replacement: paso 2, imagen 2 de 3 Black and Decker CM0700BZ Shower Head Replacement: paso 2, imagen 3 de 3
    • Place your finger, a screwdriver, or a spudger behind the corner of the tab.
    • Pull up on the tab until it disconnects from the coffee maker.
  3. Black and Decker CM0700BZ Shower Head Replacement: paso 3, imagen 1 de 3 Black and Decker CM0700BZ Shower Head Replacement: paso 3, imagen 2 de 3 Black and Decker CM0700BZ Shower Head Replacement: paso 3, imagen 3 de 3
    • Push the lid while holding the tab.
    • The lid should open fully with the top of the lid facing down.
  4. Black and Decker CM0700BZ Shower Head Replacement: paso 4, imagen 1 de 2 Black and Decker CM0700BZ Shower Head Replacement: paso 4, imagen 2 de 2
    • Lift up the shower head while the lid is lying flat.
    • Squeeze the tabs together until one peg comes loose from the insert.
    • Pull the other peg from the insert and remove the shower head from the lid.
Conclusión
Shawn Robichaud
Miembro Desde 10/26/22
729 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 197
