Introducción
The air filter on the Bissell Air180 is an easily replaceable meshed filtration device that ensures the highest quality is to come out of the fan of the device. The filter is the point of contact and barrier in the device between the polluted air and the purification of the air. This is often the main replacement or most common replacement that will be conducted on the device. This guide can be used to remove the air filter for cleaning or to remove and replace the air filter. If the air purifier is overheating, making an unusual noise, or has poor airflow, then refer to these sections of our troubleshooting page and follow these steps to remove and replace it.
Squeeze the clip on the back panel of the bottom housing and pull the panel away from the housing, exposing the air filter.
