Introducción
Follow these instructions to replace a damaged throttle control. Optionally, you may also replace the attached throttle control cable.
Qué necesitas
Use a Phillips #2 driver to remove the two screws securing the throttle control.
While removing the screws, use a 3/8" wrench to counter-hold the lock nuts and prevent them from rotating.
4 personas más completaron esta guía.
