Saltar al contenido principal
Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement
Qué necesitas
  1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement, Throttle Cable: paso 1, imagen 1 de 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement, Throttle Cable: paso 1, imagen 2 de 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement, Throttle Cable: paso 1, imagen 3 de 3
    • Cut and remove any zip ties securing the throttle cable.
  2. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 2, imagen 1 de 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #2 driver to remove the screw securing the lower end of the throttle cable.
  3. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 3, imagen 1 de 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 3, imagen 2 de 2
    • Remove the bracket securing the lower end of the throttle cable.
  4. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 4, imagen 1 de 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 4, imagen 2 de 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 4, imagen 3 de 3
    • Rotate the lower end of the throttle cable to detach it from the throttle.
  5. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 5, imagen 1 de 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 5, imagen 2 de 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 5, imagen 3 de 3
    • When reinstalling the throttle control cable, check to make sure that the throttle control moves the throttle through its full range of motion.
    • If necessary, loosen the screw securing the lower end of the throttle cable and adjust the position of the cable. Re-tighten the screw and check to make sure that the throttle moves through its full range of motion.
  6. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 6, imagen 1 de 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 6, imagen 2 de 2
    • Use a 7/16" wrench or deep socket to remove the cap from the throttle control.
  7. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 7, imagen 1 de 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 7, imagen 2 de 2
    • Advance the throttle control to expose the gear rack containing the upper end of the throttle cable.
  8. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 8, imagen 1 de 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 8, imagen 2 de 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 8, imagen 3 de 3
    • Separate the gear rack from the upper end of the throttle cable.
    • Lift and remove the gear rack from the throttle control.
    • If the gear rack doesn't fully detach, advance the throttle control lever a little farther.
    • Lubricate the gear rack with a bit of lithium grease during reassembly.
  9. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 9, imagen 1 de 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 9, imagen 2 de 3 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Cable Replacement: paso 9, imagen 3 de 3
    • Use a 1/2" wrench to unscrew the upper end of the throttle cable from the throttle control.
    • Slide the throttle cable down out of the bottom of the throttle control, and remove the cable.
Conclusión
Una persona más ha completado esta guía.
Jeff Suovanen
Miembro Desde 08/06/13
429,049 Reputación
259 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,432 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 33
Todo El Tiempo: 1,904
