Saltar al contenido principal
Beats Studio 2 Wireless Bluetooth Board Replacement
Qué necesitas
  1. Beats Studio 2 Wireless Bluetooth Board Replacement, Ear Cushion: paso 1, imagen 1 de 2 Beats Studio 2 Wireless Bluetooth Board Replacement, Ear Cushion: paso 1, imagen 2 de 2
    • Insert a spudger between the plastic part of the left headphone and the ear cushion.
    • Work the spudger around the periphery of the base of the cushion and gently pry it off the head phone.
  2. Beats Studio 2 Wireless Bluetooth Board Replacement: paso 2, imagen 1 de 3 Beats Studio 2 Wireless Bluetooth Board Replacement: paso 2, imagen 2 de 3 Beats Studio 2 Wireless Bluetooth Board Replacement: paso 2, imagen 3 de 3
    • Pull the rest of the cushion away from the adhesive with your hands.
  3. Beats Studio 2 Wireless Bluetooth Board Replacement, Speaker: paso 3, imagen 1 de 2 Beats Studio 2 Wireless Bluetooth Board Replacement, Speaker: paso 3, imagen 2 de 2
    • Using the Phillips #00 screwdriver, remove the screws holding the speaker in place.
    • If the speaker is on the side with the charging port be sure to keep the two screws holding the charging port separate.
  4. Beats Studio 2 Wireless Bluetooth Board Replacement: paso 4, imagen 1 de 1
    • Gently separate the speaker from the headphones.
    • Don't pull or yank the speaker from the headphones. They are connected together by wires that might be damaged.
  5. Beats Studio 2 Wireless Bluetooth Board Replacement: paso 5, imagen 1 de 2 Beats Studio 2 Wireless Bluetooth Board Replacement: paso 5, imagen 2 de 2
    • Gently pull the wire with rubber connectors off of the speaker.
  6. Beats Studio 2 Wireless Bluetooth Board Replacement: paso 6, imagen 1 de 1
    • Use a soldering iron to desolder the two connections.
    • For details on how to solder and desolder, refer to the How to Solder and Desolder Connections guide.
    • A soldering iron can produce very high temperatures, and can burn skin. Use with caution.
    • Note the position of the speaker in its housing, then carefully remove the faulty speaker.
  7. Beats Studio 2 Wireless Bluetooth Board Replacement, Bluetooth Board: paso 7, imagen 1 de 1
    • Peel off the sticker underneath the speaker.
  8. Beats Studio 2 Wireless Bluetooth Board Replacement: paso 8, imagen 1 de 1
    • Remove the center screw using a Phillips #00 screwdriver.
  9. Beats Studio 2 Wireless Bluetooth Board Replacement: paso 9, imagen 1 de 1
    • Separate the plastic case from the rubber backing by hand or with a spudger.
  10. Beats Studio 2 Wireless Bluetooth Board Replacement: paso 10, imagen 1 de 2 Beats Studio 2 Wireless Bluetooth Board Replacement: paso 10, imagen 2 de 2
    • Use a Phillips #00 to remove the four screws securing the case on top of the Bluetooth board.
  11. Beats Studio 2 Wireless Bluetooth Board Replacement: paso 11, imagen 1 de 1
    • Use a spudger to gently pry the left headband clip to free the earphone from the hinge.
    • This picture shows this for the right earphone, but the process should be exactly the same for the left side.
  12. Beats Studio 2 Wireless Bluetooth Board Replacement: paso 12, imagen 1 de 1
    • Slide the front case down to separate it from the back and reveal the Bluetooth board.
  13. Beats Studio 2 Wireless Bluetooth Board Replacement: paso 13, imagen 1 de 2 Beats Studio 2 Wireless Bluetooth Board Replacement: paso 13, imagen 2 de 2
    • Remove the four screws from the Bluetooth board with the Phillips #00 screwdriver.
    • This will free the Bluetooth board from the back case.
  14. Beats Studio 2 Wireless Bluetooth Board Replacement: paso 14, imagen 1 de 2 Beats Studio 2 Wireless Bluetooth Board Replacement: paso 14, imagen 2 de 2
    • Remove the Bluetooth board from the case.
    • Remove the translucent sticker from the back of the Bluetooth board.
  15. Beats Studio 2 Wireless Bluetooth Board Replacement: paso 15, imagen 1 de 1
    • Use the pointed tip of a spudger to carefully push on each side of the connector to remove it from the socket.
  16. Beats Studio 2 Wireless Bluetooth Board Replacement: paso 16, imagen 1 de 1
    • Desolder the RYB connectors, and the connector attached to the black wire using a soldering iron.
    • For information on desoldering connections, see the How to Solder and Desolder Connections Guide.
    • The soldering iron can reach very high temperatures. Use it with caution.
Conclusión
2 personas más completaron esta guía.
Jack Wilson
Miembro Desde 03/20/23
494 Reputación
2 Guías creadas
Equipo
Un comentario
Hi, can you help me out with a wiring diagram to the bluetooth board, all my wires got torn loose from my old board and i do not know where to solder the new wires to which connections. If you could post a picture with which coloured wires go where , that would be most helpful, thanks.
Roger Bee_44 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 84
Todo El Tiempo: 999
