Saltar al contenido principal
Beats Studio 2 Wireless Battery Replacement
Qué necesitas
  1. Beats Studio 2 Wireless Battery Replacement, Battery: paso 1, imagen 1 de 2 Beats Studio 2 Wireless Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Using a spudger, remove the panel circling the ‘b’ Beats logo on the right earphone by applying pressure upwards under the panel until it is removed.
  2. Beats Studio 2 Wireless Battery Replacement: paso 2, imagen 1 de 2 Beats Studio 2 Wireless Battery Replacement: paso 2, imagen 2 de 2
    • Remove the four screws securing the housing with a Phillips #00 screwdriver.
  3. Beats Studio 2 Wireless Battery Replacement: paso 3, imagen 1 de 1
    • Use a spudger to release the clip in the seam under the silver “studio” label.
    • Remove the right side of the headband.
  4. Beats Studio 2 Wireless Battery Replacement: paso 4, imagen 1 de 1
    • Gently remove the right earphone speaker from the headband by sliding the speaker downwards.
  5. Beats Studio 2 Wireless Battery Replacement: paso 5, imagen 1 de 3 Beats Studio 2 Wireless Battery Replacement: paso 5, imagen 2 de 3 Beats Studio 2 Wireless Battery Replacement: paso 5, imagen 3 de 3
    • Use the pointed tip of a spudger to carefully push on each side of the connector to release it from the socket on the motherboard.
    • Be gentle with the connectors as they can break easily.
    • Don't use a metal spudger to remove a battery or any internal component. This is potentially dangerous as it could puncture the battery and cause a fire or worse.
    • Use a nylon spudger to remove the battery from the headphones.
Conclusión
2 personas más completaron esta guía.
Jack Wilson
Miembro Desde 03/20/23
494 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 40
Ultimos 30 días: 180
Todo El Tiempo: 2,313
