Saltar al contenido principal
Backbone One Right Trigger Replacement
Qué necesitas
  1. Backbone One Right Trigger Replacement, Remove the screws: paso 1, imagen 1 de 1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Right Trigger Replacement, Rotate the upper part: paso 2, imagen 1 de 3 Backbone One Right Trigger Replacement, Rotate the upper part: paso 2, imagen 2 de 3 Backbone One Right Trigger Replacement, Rotate the upper part: paso 2, imagen 3 de 3
    • Lift up the upper cover of the controller.
    • Swing the upper cover over and place it on the controller case.
    • Make sure that the interconnecting cable has no tension.
  3. Backbone One Right Trigger Replacement, Remove the protective tape: paso 3, imagen 1 de 3 Backbone One Right Trigger Replacement, Remove the protective tape: paso 3, imagen 2 de 3 Backbone One Right Trigger Replacement, Remove the protective tape: paso 3, imagen 3 de 3
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
  4. Backbone One Right Trigger Replacement, Open the interconnect cable ZIF connector: paso 4, imagen 1 de 3 Backbone One Right Trigger Replacement, Open the interconnect cable ZIF connector: paso 4, imagen 2 de 3 Backbone One Right Trigger Replacement, Open the interconnect cable ZIF connector: paso 4, imagen 3 de 3
    • Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
  5. Backbone One Right Trigger Replacement, Disconnect the interconnect cable: paso 5, imagen 1 de 2 Backbone One Right Trigger Replacement, Disconnect the interconnect cable: paso 5, imagen 2 de 2
    • Disconnect the cable by pulling it straight out the ZIF connector.
  6. Backbone One Right Trigger Replacement, Disconnect the phone connector cables: paso 6, imagen 1 de 3 Backbone One Right Trigger Replacement, Disconnect the phone connector cables: paso 6, imagen 2 de 3 Backbone One Right Trigger Replacement, Disconnect the phone connector cables: paso 6, imagen 3 de 3
    • Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
  7. Backbone One Right Trigger Replacement, Separate the upper case: paso 7, imagen 1 de 1
    • Separate the the upper case of the left controller handle.
  8. Backbone One Right Trigger Replacement, Remove the screws: paso 8, imagen 1 de 1
    • Use a Phillips screwdriver to remove the three 5.9 mm-long screws.
  9. Backbone One Right Trigger Replacement, Remove the trigger: paso 9, imagen 1 de 2 Backbone One Right Trigger Replacement, Remove the trigger: paso 9, imagen 2 de 2
    • Remove the trigger.
Conclusión
Opening didn’t go as planned? Answers community for help.
Adriana Zwink
Miembro Desde 12/18/19
45,259 Reputación
167 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
142 Miembros
16,235 Guías creadas
2 comentarios
where can I buy a right trigger replacement?
pelony felony - Contestar
Ricardo Gazo Rosario - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 27
Todo El Tiempo: 571
