Saltar al contenido principal
BLU Energy X Motherboard Replacement
Qué necesitas
  1. BLU Energy X Motherboard Replacement, Battery: paso 1, imagen 1 de 3 BLU Energy X Motherboard Replacement, Battery: paso 1, imagen 2 de 3 BLU Energy X Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the back case using plastic opening tool.
  2. BLU Energy X Motherboard Replacement: paso 2, imagen 1 de 2 BLU Energy X Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the seven 4mm Phillips #000 screws.
    • Remove the top plate.
  3. BLU Energy X Motherboard Replacement: paso 3, imagen 1 de 3 BLU Energy X Motherboard Replacement: paso 3, imagen 2 de 3 BLU Energy X Motherboard Replacement: paso 3, imagen 3 de 3
    • Detach the battery from the mother board using a plastic opening tool.
    • Use a plastic spudger to remove battery.
  4. BLU Energy X Motherboard Replacement, Motherboard: paso 4, imagen 1 de 2 BLU Energy X Motherboard Replacement, Motherboard: paso 4, imagen 2 de 2
    • Use the flat end of a spudger to flip up the black retaining flap on the ZIF connector.
  5. BLU Energy X Motherboard Replacement: paso 5, imagen 1 de 2 BLU Energy X Motherboard Replacement: paso 5, imagen 2 de 2
    • Gently pull the ribbon cable free of the ZIF connector.
  6. BLU Energy X Motherboard Replacement: paso 6, imagen 1 de 2 BLU Energy X Motherboard Replacement: paso 6, imagen 2 de 2
    • Gently peel up the antenna.
    • This is secured with some light adhesive, so some force may be required.
  7. BLU Energy X Motherboard Replacement: paso 7, imagen 1 de 3 BLU Energy X Motherboard Replacement: paso 7, imagen 2 de 3 BLU Energy X Motherboard Replacement: paso 7, imagen 3 de 3
    • Gently rotate the motherboard up so that the front-facing camera is pointed towards you.
    • Use the pointed end of a spudger to disconnect the antenna cable and the ribbon cable.
  8. BLU Energy X Motherboard Replacement: paso 8, imagen 1 de 2 BLU Energy X Motherboard Replacement: paso 8, imagen 2 de 2
    • Lift the motherboard up and out of the device.
Conclusión
Una persona más ha completado esta guía.
Geoff Wacker
Miembro Desde 09/30/13
90,075 Reputación
89 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 423
