Saltar al contenido principal
BLU Advance 4.0 Screen Replacement
Qué necesitas
  1. Aviso: los pasos 1-3 provienen de una guía que está marcada como "En progreso".
    BLU Advance 4.0 Screen Replacement, Removing the back cover: paso 1, imagen 1 de 2 BLU Advance 4.0 Screen Replacement, Removing the back cover: paso 1, imagen 2 de 2
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
  2. BLU Advance 4.0 Screen Replacement, Revealing the motherboard: paso 2, imagen 1 de 3 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: paso 2, imagen 2 de 3 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: paso 2, imagen 3 de 3
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
  3. BLU Advance 4.0 Screen Replacement, Separating motherboard from screen: paso 3, imagen 1 de 1
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
Conclusión
5 personas más completaron esta guía.
Jon Sclar
Miembro Desde 11/13/14
292 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 2,328
