Saltar al contenido principal
BLU Advance 4.0 Rear Case Disassembly
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. BLU Advance 4.0 Rear Case Disassembly, Removing the back cover: paso 1, imagen 1 de 2 BLU Advance 4.0 Rear Case Disassembly, Removing the back cover: paso 1, imagen 2 de 2
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
  2. BLU Advance 4.0 Rear Case Disassembly, Revealing the motherboard: paso 2, imagen 1 de 3 BLU Advance 4.0 Rear Case Disassembly, Revealing the motherboard: paso 2, imagen 2 de 3 BLU Advance 4.0 Rear Case Disassembly, Revealing the motherboard: paso 2, imagen 3 de 3
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
  3. BLU Advance 4.0 Rear Case Disassembly, Separating motherboard from screen: paso 3, imagen 1 de 1
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
Conclusión
Una persona más ha completado esta guía.
David Okide
Miembro Desde 10/19/14
14 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 21
Todo El Tiempo: 8,375
