Saltar al contenido principal
BLU Advance 4.0 Charger Port Replacement
Qué necesitas
  1. Aviso: los pasos 1-3 provienen de una guía que está marcada como "En progreso".
    BLU Advance 4.0 Charger Port Replacement, Removing the back cover: paso 1, imagen 1 de 2 BLU Advance 4.0 Charger Port Replacement, Removing the back cover: paso 1, imagen 2 de 2
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
  2. BLU Advance 4.0 Charger Port Replacement, Revealing the motherboard: paso 2, imagen 1 de 3 BLU Advance 4.0 Charger Port Replacement, Revealing the motherboard: paso 2, imagen 2 de 3 BLU Advance 4.0 Charger Port Replacement, Revealing the motherboard: paso 2, imagen 3 de 3
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
  3. BLU Advance 4.0 Charger Port Replacement, Separating motherboard from screen: paso 3, imagen 1 de 1
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
  4. BLU Advance 4.0 Charger Port Replacement, Charger Port: paso 4, imagen 1 de 2 BLU Advance 4.0 Charger Port Replacement, Charger Port: paso 4, imagen 2 de 2
    • Once phone is completely disassmbled, you will take your soldering iron to the charger port to remove it.
    • Be careful to make sure you take a soldering wick to absorb the solder.
    • Touching other pieces on the motherboard may alter phones capabilities!
  5. BLU Advance 4.0 Charger Port Replacement: paso 5, imagen 1 de 1
    • Once the old charger port is removed, take the new one and place it in the same spot. You will need to solder this piece to ensure that it stays connected.
Conclusión
4 personas más completaron esta guía.
Jon Sclar
Miembro Desde 11/13/14
292 Reputación
3 Guías creadas
Equipo
Un comentario
Where can I get a charging port for my BLU studio XL2
Debbie - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 1,461
