Saltar al contenido principal
Auking M8-F PCB Button Panel Replacement
Qué necesitas
  1. Auking M8-F PCB Button Panel Replacement, PCB Button Panel: paso 1, imagen 1 de 2 Auking M8-F PCB Button Panel Replacement, PCB Button Panel: paso 1, imagen 2 de 2
    • Make sure that the device is unplugged from any power source before attempting any repairs.
    • Flip the projector on its opposite side.
    • Remove all six of the 11 mm screws using a Phillips #1 screwdriver.
    • Remove the two 14 mm screws using a Phillips #1 screwdriver.
  2. Auking M8-F PCB Button Panel Replacement: paso 2, imagen 1 de 2 Auking M8-F PCB Button Panel Replacement: paso 2, imagen 2 de 2
    • Carefully prop open the top of the projector.
    • Disconnect the cable attached to the top lid.
    • Remove the top lid.
  3. Auking M8-F PCB Button Panel Replacement: paso 3, imagen 1 de 2 Auking M8-F PCB Button Panel Replacement: paso 3, imagen 2 de 2
    • Remove the wire cord attached to the top panel to separate both the top panel and the wire cord.
  4. Auking M8-F PCB Button Panel Replacement: paso 4, imagen 1 de 3 Auking M8-F PCB Button Panel Replacement: paso 4, imagen 2 de 3 Auking M8-F PCB Button Panel Replacement: paso 4, imagen 3 de 3
    • Remove six of the 5 mm screws using a Phillips #00 screwdriver to detach the power panel.
    • Remove the power panel.
Conclusión
Aubrey Haynes
Miembro Desde 09/13/23
277 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 83
