Saltar al contenido principal
Audio Technica ATH-M50 Ear pads Replacement
  1. Audio Technica ATH-M50 Ear pads Replacement, Preparing Ear pads for removal: paso 1, imagen 1 de 1
    • Unfold the headphones and lay down flat with the pads facing up
    • Once facing up ,tuck your fingers under the edge of the inside of the ear pad and carefully pull up until the ear pad starts to come off
  2. Audio Technica ATH-M50 Ear pads Replacement, Removing the ear pad: paso 2, imagen 1 de 1
    • After creating a gap continue to lift the ear pad off until fully removed
    • For reinstalling the ear pads use the same techniques for a easy installation
    • On older headphones the foam sponge part of the ear pad can deteriorate,it is recommended that if there is any leftover foam that it is remove to the best of your ability to improve the longevity of the headphone,the drivers are delicate please be careful:-)
    • Congratulations you have now removed your M50’s ear pads:-)
Conclusión
2 personas más completaron esta guía.
HelloMacOS
Miembro Desde 01/24/22
26,006 Reputación
11 Guías creadas
Equipo
Repair is War on Entropy Miembro de Repair is War on Entropy
Community
25 Miembros
1,156 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 36
Todo El Tiempo: 962
