Saltar al contenido principal
AuKing M8-F Bulb Replacement
Qué necesitas
  1. AuKing M8-F Bulb Replacement, Motherboard: paso 1, imagen 1 de 2 AuKing M8-F Bulb Replacement, Motherboard: paso 1, imagen 2 de 2
    • Make sure that the device is unplugged from any power source before attempting any repairs.
    • Flip the projector on its opposite side.
    • Remove all six of the 11 mm screws on the base of the projector using a Phillips #1 screwdriver.
    • Remove the two 14 mm screws using a Phillips #1 screwdriver.
  2. AuKing M8-F Bulb Replacement: paso 2, imagen 1 de 3 AuKing M8-F Bulb Replacement: paso 2, imagen 2 de 3 AuKing M8-F Bulb Replacement: paso 2, imagen 3 de 3
    • Carefully prop open the top of the projector.
    • To remove the cord that is attached to the top, carefully wiggle the cord out.
    • Remove the top lid.
  3. AuKing M8-F Bulb Replacement: paso 3, imagen 1 de 3 AuKing M8-F Bulb Replacement: paso 3, imagen 2 de 3 AuKing M8-F Bulb Replacement: paso 3, imagen 3 de 3
    • Flip up the black locking flaps then remove the two ribbon cables.
  4. AuKing M8-F Bulb Replacement: paso 4, imagen 1 de 2 AuKing M8-F Bulb Replacement: paso 4, imagen 2 de 2
    • Remove the two 9 mm screws using the Phillips #00 screwdriver.
  5. AuKing M8-F Bulb Replacement: paso 5, imagen 1 de 2 AuKing M8-F Bulb Replacement: paso 5, imagen 2 de 2
    • Carefully disconnect the wires that are attached to the motherboard.
    • Remove the motherboard.
  6. AuKing M8-F Bulb Replacement, Bulb: paso 6, imagen 1 de 2 AuKing M8-F Bulb Replacement, Bulb: paso 6, imagen 2 de 2
    • Remove the six 9 mm screws using a Phillips #0 screwdriver to detach both of the black panels.
  7. AuKing M8-F Bulb Replacement: paso 7, imagen 1 de 3 AuKing M8-F Bulb Replacement: paso 7, imagen 2 de 3 AuKing M8-F Bulb Replacement: paso 7, imagen 3 de 3
    • Slide the motherboard upwards to remove the wire component connected to the LED bulb.
    • Gently remove the LED bulb and the attached heatsink from the projector
Conclusión
Aubrey Haynes
Miembro Desde 09/13/23
277 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 64
Todo El Tiempo: 388
