Saltar al contenido principal
Asus ZenBook UX430UA Battery Replacement
Qué necesitas
  1. Asus ZenBook UX430UA Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Hold the power button to turn off the laptop.
  2. Asus ZenBook UX430UA Battery Replacement: paso 2, imagen 1 de 2 Asus ZenBook UX430UA Battery Replacement: paso 2, imagen 2 de 2
    • Remove the seven T5 Torx screws securing the bottom case to the chassis.
    • Remove the two T5 Torx screws that are threaded differently.
    • The top left and top right screws use different threads than the rest of the screws and should be kept separately to avoid damage.
  3. Asus ZenBook UX430UA Battery Replacement: paso 3, imagen 1 de 1
    • Remove the two rubber feet from the bottom casing.
    • Remove the two screws holding the bottom casing to the chassis using a Phillips #1 screwdriver.
  4. Asus ZenBook UX430UA Battery Replacement: paso 4, imagen 1 de 2 Asus ZenBook UX430UA Battery Replacement: paso 4, imagen 2 de 2
    • Use an iFixit opening tool to gently pry open the bottom case away from the top case.
    • The bottom case is secured to the upper case with four plastic clips near the edges of the laptop.
    • Gently pull the lower case away from the upper case of the laptop by lifting the top first.
  5. Asus ZenBook UX430UA Battery Replacement: paso 5, imagen 1 de 1
    • Use a Phillips 1 screwdriver to remove the five screws holding the battery to the motherboard.
  6. Asus ZenBook UX430UA Battery Replacement: paso 6, imagen 1 de 2 Asus ZenBook UX430UA Battery Replacement: paso 6, imagen 2 de 2
    • Carefully lift the battery from the bottom casing.
    • While removing the battery, ensure that the battery connector is raised enough so that it doesn't get in contact with the motherboard.
    • Lithium-ion batteries can be dangerous if handled poorly. Be cautious to not let any sharp objects near the battery to avoid puncturing it. Use the correct procedures to recycle the battery in your region.
Conclusión
Una persona más ha completado esta guía.
Tanveer Saini
Miembro Desde 09/27/22
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 37
Ultimos 30 días: 186
Todo El Tiempo: 4,368
