Saltar al contenido principal
Asus ZenBook Flip UX360C Speaker Replacement
Qué necesitas
  1. Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: paso 1, imagen 1 de 3 Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: paso 1, imagen 2 de 3 Asus ZenBook Flip UX360C Speaker Replacement, Rubber Feet: paso 1, imagen 3 de 3
    • Turn laptop over.
    • Use the metal spudger to pry rubber feet off in the four corners of laptop.
  2. Asus ZenBook Flip UX360C Speaker Replacement, Speaker: paso 2, imagen 1 de 1
    • Attach an ESD wristband to your wrist and clip the grounding clamp to a grounded metal object.
  3. Asus ZenBook Flip UX360C Speaker Replacement: paso 3, imagen 1 de 1
    • Remove all eleven 5 mm, Phillips #1 screws on the back cover.
  4. Asus ZenBook Flip UX360C Speaker Replacement: paso 4, imagen 1 de 1
    • Use a plastic opening tool to remove the keyboard panel.
  5. Asus ZenBook Flip UX360C Speaker Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to disconnect the ZIF keyboard ribbon cable from the motherboard.
  6. Asus ZenBook Flip UX360C Speaker Replacement: paso 6, imagen 1 de 3 Asus ZenBook Flip UX360C Speaker Replacement: paso 6, imagen 2 de 3 Asus ZenBook Flip UX360C Speaker Replacement: paso 6, imagen 3 de 3
    • Use nylon-tipped tweezeres to detach the battery connection.
  7. Asus ZenBook Flip UX360C Speaker Replacement: paso 7, imagen 1 de 1
    • Remove all ten Phillips #1 battery retaining screws.
  8. Asus ZenBook Flip UX360C Speaker Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, carefully remove the connector connecting the speakers to the motherboard.
  9. Asus ZenBook Flip UX360C Speaker Replacement: paso 9, imagen 1 de 3 Asus ZenBook Flip UX360C Speaker Replacement: paso 9, imagen 2 de 3 Asus ZenBook Flip UX360C Speaker Replacement: paso 9, imagen 3 de 3
    • Use your fingers or another object to slightly raise the bottom edge of the battery. The battery does not need to be fully removed to replace the speakers.
    • Use a nylon spudger or an opening tool to carefully pry the speaker from the chassis.
    • The speaker is held down with a mild adhesive. Work your way around the border to fully remove the speaker.
  10. Asus ZenBook Flip UX360C Speaker Replacement: paso 10, imagen 1 de 2 Asus ZenBook Flip UX360C Speaker Replacement: paso 10, imagen 2 de 2
    • Use tweezers to carefully unseat the cable connecting the left and right speakers.
  11. Asus ZenBook Flip UX360C Speaker Replacement: paso 11, imagen 1 de 3 Asus ZenBook Flip UX360C Speaker Replacement: paso 11, imagen 2 de 3 Asus ZenBook Flip UX360C Speaker Replacement: paso 11, imagen 3 de 3
Conclusión
Equipo
IUPUI, Team 1-4, Harley Spring 2022 Miembro de IUPUI, Team 1-4, Harley Spring 2022
IUPUI-HARLEY-S22S1G4
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 521
