Saltar al contenido principal
Asus ZenBook Flip UX360C Screen Replacement
Qué necesitas
  1. Asus ZenBook Flip UX360C Screen Replacement, Screen: paso 1, imagen 1 de 2 Asus ZenBook Flip UX360C Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Use a spudger to pry out the two rubber grommets from the front of the screen.
    • Remove the two 4mm Phillips Head #1 screws behind the grommets.
  2. Asus ZenBook Flip UX360C Screen Replacement: paso 2, imagen 1 de 1
    • Use a large plastic opening tool to work around the outside of the screen and gently separate the two halves.
  3. Asus ZenBook Flip UX360C Screen Replacement: paso 3, imagen 1 de 1
    • Remove the two 2 mm Phillips #00 camera screws.
    • Remove the 2 mm Phillips #0 upper circuit board screw.
    • Remove the 2 mm Phillips #0 lower circuit board screw.
  4. Asus ZenBook Flip UX360C Screen Replacement: paso 4, imagen 1 de 2 Asus ZenBook Flip UX360C Screen Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to unplug the two ribbon cables from the top half of the screen.
    • Detach the upper circuit board cable using the same method.
  5. Asus ZenBook Flip UX360C Screen Replacement: paso 5, imagen 1 de 3 Asus ZenBook Flip UX360C Screen Replacement: paso 5, imagen 2 de 3 Asus ZenBook Flip UX360C Screen Replacement: paso 5, imagen 3 de 3
    • On the bottom half of the screen remove the screen connection.
    • Disconnect the lower circuit board cable.
    • Separate the wiring from the casing, and remove the screen.
Conclusión
Equipo
IUPUI, Team 1-4, Harley Spring 2022 Miembro de IUPUI, Team 1-4, Harley Spring 2022
IUPUI-HARLEY-S22S1G4
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 10
Ultimos 30 días: 39
Todo El Tiempo: 1,894
