Saltar al contenido principal
Asus X553MA-BPD07051 RAM Replacement
Qué necesitas
  1. Asus X553MA-BPD07051 RAM Replacement, Battery: paso 1, imagen 1 de 2 Asus X553MA-BPD07051 RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
  2. Asus X553MA-BPD07051 RAM Replacement: paso 2, imagen 1 de 1
    • Lift the edges of the keyboard using the plastic iFixit opening tool and raise the keyboard slightly to see the inside of the laptop.
    • Do not lift the keyboard too high as the keyboard is connected to the motherboard by two ribbon connectors that must be detached.
  3. Asus X553MA-BPD07051 RAM Replacement: paso 3, imagen 1 de 2 Asus X553MA-BPD07051 RAM Replacement: paso 3, imagen 2 de 2
    • Lift back the clip on the ribbon tape, and pull the tape out in order to remove the keyboard from the laptop.
    • Remove both pieces of the ribbon tape connecting the keyboard to the motherboard.
  4. Asus X553MA-BPD07051 RAM Replacement: paso 4, imagen 1 de 1
    • Remove the bundled cable connector attaching the battery to the motherboard with the plastic iFixit opening tool.
    • Make sure that you do not remove the entire connector by applying too much force. Only the white plastic connector should be removed from the metal part on the motherboard.
  5. Asus X553MA-BPD07051 RAM Replacement: paso 5, imagen 1 de 2 Asus X553MA-BPD07051 RAM Replacement: paso 5, imagen 2 de 2
    • Use Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws attaching the battery to the laptop.
  6. Asus X553MA-BPD07051 RAM Replacement: paso 6, imagen 1 de 2 Asus X553MA-BPD07051 RAM Replacement: paso 6, imagen 2 de 2
    • Lift the battery up and remove it completely from the laptop.
  7. Asus X553MA-BPD07051 RAM Replacement, Hard Drive: paso 7, imagen 1 de 2 Asus X553MA-BPD07051 RAM Replacement, Hard Drive: paso 7, imagen 2 de 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws that are securing the hard drive.
  8. Asus X553MA-BPD07051 RAM Replacement: paso 8, imagen 1 de 2 Asus X553MA-BPD07051 RAM Replacement: paso 8, imagen 2 de 2
    • Lift the hard drive up and pull it towards the screen so that it disconnects from the motherboard.
    • Use caution when disconnecting the hard drive from the motherboard, so that neither connector gets broken.
  9. Asus X553MA-BPD07051 RAM Replacement, Optical Drive: paso 9, imagen 1 de 2 Asus X553MA-BPD07051 RAM Replacement, Optical Drive: paso 9, imagen 2 de 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the one 6.0 mm screw holding in the optical drive.
  10. Asus X553MA-BPD07051 RAM Replacement: paso 10, imagen 1 de 2 Asus X553MA-BPD07051 RAM Replacement: paso 10, imagen 2 de 2
    • Gently slide the optical drive out from the motherboard.
  11. Asus X553MA-BPD07051 RAM Replacement, Motherboard: paso 11, imagen 1 de 3 Asus X553MA-BPD07051 RAM Replacement, Motherboard: paso 11, imagen 2 de 3 Asus X553MA-BPD07051 RAM Replacement, Motherboard: paso 11, imagen 3 de 3
    • Remove the bundled cable connector that connects the fan to the motherboard using the plastic iFixit opening tool.
    • Remove the bundled cable connector that attaches the audio to the motherboard with the plastic iFixit opening tool.
  12. Asus X553MA-BPD07051 RAM Replacement: paso 12, imagen 1 de 2 Asus X553MA-BPD07051 RAM Replacement: paso 12, imagen 2 de 2
    • Lift the metal clip holding the ZIF connector ribbon down.
    • Pull the ribbon out from the connector, away from the motherboard.
  13. Asus X553MA-BPD07051 RAM Replacement: paso 13, imagen 1 de 2 Asus X553MA-BPD07051 RAM Replacement: paso 13, imagen 2 de 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the five 6.0 mm screws attaching the motherboard to the base of the laptop.
  14. Asus X553MA-BPD07051 RAM Replacement: paso 14, imagen 1 de 1
    • Remove the tape from the motherboard.
  15. Asus X553MA-BPD07051 RAM Replacement: paso 15, imagen 1 de 2 Asus X553MA-BPD07051 RAM Replacement: paso 15, imagen 2 de 2
    • Lift the metal clips holding the ZIF connector down.
    • Push the gold metal connector away from the motherboard.
    • Be careful not to break the connector.
  16. Asus X553MA-BPD07051 RAM Replacement: paso 16, imagen 1 de 2 Asus X553MA-BPD07051 RAM Replacement: paso 16, imagen 2 de 2
    • Lift the coaxial connector from the wifi chip with the plastic iFixit opening tool.
  17. Asus X553MA-BPD07051 RAM Replacement: paso 17, imagen 1 de 3 Asus X553MA-BPD07051 RAM Replacement: paso 17, imagen 2 de 3 Asus X553MA-BPD07051 RAM Replacement: paso 17, imagen 3 de 3
    • Lift the motherboard to remove it fully.
    • Do not pull too hard, the motherboard should come off easily once it has been separated from the base of the laptop.
  18. Asus X553MA-BPD07051 RAM Replacement, RAM: paso 18, imagen 1 de 3 Asus X553MA-BPD07051 RAM Replacement, RAM: paso 18, imagen 2 de 3 Asus X553MA-BPD07051 RAM Replacement, RAM: paso 18, imagen 3 de 3
    • Remove the RAM by lifting and pulling it up from the back of the motherboard.
Conclusión
2 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team S1-G4, Botvin Fall 2019 Miembro de UMass Dartmouth, Team S1-G4, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G4
Miembros de 3
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 32
Todo El Tiempo: 1,957
