Introducción
If you are having trouble with your Asus X553MA-BPD07051 running very slow or giving you the Blue Screen of Death, check what the RAM is running at. If it is running at 40% or higher, your RAM should be replaced. For additional information, check out this troubleshooting page. Use this page to assist you in replacing your RAM. Before beginning, make sure that the laptop has been turned off and battery removed first in order to avoid being shocked.
Qué necesitas
Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
Use a Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws that are securing the hard drive.
Use a Phillips #0 screwdriver (PH0 bit) to remove the one 6.0 mm screw holding in the optical drive.
Remove the bundled cable connector that connects the fan to the motherboard using the plastic iFixit opening tool.
Remove the bundled cable connector that attaches the audio to the motherboard with the plastic iFixit opening tool.
2 personas más completaron esta guía.
