Saltar al contenido principal
Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement
Qué necesitas
  1. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement, Battery: paso 1, imagen 1 de 1
    • Use a metal spudger to pry the bottom panel open.
    • Be gentle around the edges.
    • Lift the back panel to expose the inside of the laptop.
  2. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: paso 2, imagen 1 de 2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: paso 2, imagen 2 de 2
    • Using the same Phillips #0 screwdriver, remove the eight black 50mm screws surrounding the battery.
  3. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using a set of precision tweezers, lift the motherboard connector tab.
  4. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: paso 4, imagen 1 de 2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: paso 4, imagen 2 de 2
    • Use a nylon spudger or your fingers to gently pry the battery up.
    • Remove the battery.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  5. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement, Printed Circuit Board (PCB): paso 5, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the nine 50mm panel screws.
    • Gently remove back panel
    • Be aware of sharp metal edges once the panel is removed.
  6. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: paso 6, imagen 1 de 1
    • Use the Phillips #0 screwdriver to remove the 50mm screws around the battery.
    • Gently remove the battery to avoid damage.
  7. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: paso 7, imagen 1 de 2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: paso 7, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the five 5mm screws on the fan.
    • Peel the protective wire tape off of the multicolored wires.
  8. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: paso 8, imagen 1 de 2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: paso 8, imagen 2 de 2
    Comprar
    • Use the precision tweezers to disconnect the wires and gently remove the fan.
    • Be gentle so as not to break wires.
  9. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: paso 9, imagen 1 de 2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: paso 9, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove the eight 6mm PCB board screws.
    • Remove the PCB board.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 335
