Saltar al contenido principal
Asus VivoBook S200E-RHI3T73 Keyboard Replacement
Qué necesitas
  1. Asus VivoBook S200E-RHI3T73 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the nine 50mm screws and lift the panel.
    • Be aware of sharp metal edges once the panel is removed.
  2. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: paso 2, imagen 1 de 1
    • Use the Phillips #0 screwdriver to remove the twelve 50mm screws around the battery.
    • Gently remove the battery to avoid damage.
  3. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: paso 3, imagen 1 de 3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: paso 3, imagen 2 de 3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the Phillips #0 screwdriver to remove the five 5mm screws around the fan.
    • Use the precision tweezers to unplug the fan cords.
    • Be cautious of pulling the cords.
  4. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: paso 4, imagen 1 de 3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: paso 4, imagen 2 de 3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: paso 4, imagen 3 de 3
    • Use the Phillips#0 screwdriver to unscrew the 3.5mm screws from around the motherboard and the 6mm screws from around the PCB.
    • Double check for unloosened screws. Bending the boards can damage the hardware.
  5. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: paso 5, imagen 1 de 2 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: paso 5, imagen 2 de 2
    • Use the Phillips#0 screwdriver to remove the 50mm screws on the boarder of the metal panel.
    • Be cautious of sharp metal edges.
    • Carefully remove the panel. Without care it will bend and be difficult to reassemble.
  6. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: paso 6, imagen 1 de 1
    • Using the Phillips#0 screwdriver, remove the 50mm screws surrounding the keyboard.
    • Gently remove the keyboard.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 608
