Saltar al contenido principal
Asus Transformer Book T100TAF Touchpad Replacement
Qué necesitas
  1. Asus Transformer Book T100TAF Touchpad Replacement, Keyboard: paso 1, imagen 1 de 1
    • Detach the keyboard from the screen by depressing the silver button on the hinge and pulling upwards on the tablet.
  2. Asus Transformer Book T100TAF Touchpad Replacement: paso 2, imagen 1 de 2 Asus Transformer Book T100TAF Touchpad Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the six 4 mm screws on the underside of the device.
  3. Asus Transformer Book T100TAF Touchpad Replacement: paso 3, imagen 1 de 2 Asus Transformer Book T100TAF Touchpad Replacement: paso 3, imagen 2 de 2
    • Use a metal spudger to pry up the rubber pads covering the two upper silver screws.
    • Use a Phillips #00 screwdriver to remove the two 5.5 mm screws under the rubber pads.
  4. Asus Transformer Book T100TAF Touchpad Replacement: paso 4, imagen 1 de 3 Asus Transformer Book T100TAF Touchpad Replacement: paso 4, imagen 2 de 3 Asus Transformer Book T100TAF Touchpad Replacement: paso 4, imagen 3 de 3
    • Remove the back cover.
    • Use a Phillips #00 screwdriver to remove all the screws from the metal, inside panel, including four black 4.0 mm screws along the top.
    • Remove four black 3.0 screws along the bottom.
    • Remove the one silver 5.0 mm screw in the top right corner.
  5. Asus Transformer Book T100TAF Touchpad Replacement: paso 5, imagen 1 de 1
    • Remove the metal keyboard cover from the device.
  6. Asus Transformer Book T100TAF Touchpad Replacement: paso 6, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the 4.5 mm screw on the keyboard circuit board.
  7. Asus Transformer Book T100TAF Touchpad Replacement: paso 7, imagen 1 de 1
    • Peel the yellow tape and label away from the motherboard with the metal spudger.
  8. Asus Transformer Book T100TAF Touchpad Replacement: paso 8, imagen 1 de 1
    • Unplug the cable which leads to the hinge by gently pulling it away from the motherboard.
  9. Asus Transformer Book T100TAF Touchpad Replacement: paso 9, imagen 1 de 3 Asus Transformer Book T100TAF Touchpad Replacement: paso 9, imagen 2 de 3 Asus Transformer Book T100TAF Touchpad Replacement: paso 9, imagen 3 de 3
    • Flip up the tab on the white ribbon cable labeled “MB” using the metal spudger and then pull the white ribbon cable away from the motherboard.
    • Use a spudger to carefully flip up the black tab on the ZIF connector and pull the black striped ribbon cable away from the motherboard.
    • Don't use a metal spudger for work on the internals of your laptop. The photo in this guide is incorrect. The metal spudger is not ESD safe and could harm the components in your laptop.
  10. Asus Transformer Book T100TAF Touchpad Replacement: paso 10, imagen 1 de 1
    • Gently remove the motherboard from the keyboard by pulling up with even pressure applied to all sides of the board.
  11. Asus Transformer Book T100TAF Touchpad Replacement, Touchpad: paso 11, imagen 1 de 3 Asus Transformer Book T100TAF Touchpad Replacement, Touchpad: paso 11, imagen 2 de 3 Asus Transformer Book T100TAF Touchpad Replacement, Touchpad: paso 11, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the three black 2.0 mm screws from the track pad.
    • Lift the touchpad away from the keyboard assembly by pulling from the top edge.
Conclusión
Sarah Westberg
Miembro Desde 03/11/19
29,252 Reputación
71 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,416 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 69
