Introducción
This guide shows you how to replace the detachable keyboard of your Asus Transformer Book T100TAF. If some of your keyboard keys are not responding to your inputs, replacing your keyboard will fix that. When doing so, it is especially important to treat the fragile ribbon cables with care when removing them from their clips, as important information about key presses is transferred through these cables.
Partes
No se especificaron partes.
Detach the keyboard from the screen by depressing the silver button on the hinge and pulling upwards on the tablet.
6 personas más completaron esta guía.
Un Comentario
Très facile. Merci. Et le fait d'avoir pu démonter mon clavier et souffler la poussière à l'intérieur à fait en sorte que les touches qui ne fonctionnaient plus ont recommencé à le faire. Merci encore.
