Saltar al contenido principal
Asus ROG G752V Fan Replacement
Qué necesitas
  1. Asus ROG G752V Fan Replacement, Battery: paso 1, imagen 1 de 2 Asus ROG G752V Fan Replacement, Battery: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Make sure you disconnect the charger before starting this guide.
    • Pick out all 11 rubber plugs off of the back cover with a pair of tweezers.
  2. Asus ROG G752V Fan Replacement: paso 2, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 2, imagen 2 de 2
    • Using the Phillips #0 screwdriver, unscrew all twelve 5.2 mm screws on the back of the laptop.
    • There is one 5.2 mm screw under the rubber plug in the middle.
  3. Asus ROG G752V Fan Replacement: paso 3, imagen 1 de 1
    • Pull up the rubber seal and the service cover will come off.
  4. Asus ROG G752V Fan Replacement: paso 4, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the six 5.2 mm screws under the service cover.
  5. Asus ROG G752V Fan Replacement: paso 5, imagen 1 de 1
    • Using your hands, pull the optical drive out.
  6. Asus ROG G752V Fan Replacement: paso 6, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 6, imagen 2 de 2
    • Use the iFixit Opening Tool to pry apart the back panel from the main body of the laptop.
    • Start from the front side of the laptop and then continue to the side for easier access.
  7. Asus ROG G752V Fan Replacement: paso 7, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 7, imagen 2 de 2
    • Remove the hinge on the back of the laptop cover using the iFixit Opening Tool. The piece should pop off.
    • Be gentle with the cover because there is a speaker wire attached to it.
  8. Asus ROG G752V Fan Replacement: paso 8, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 8, imagen 2 de 2
    • Disconnect the speaker wire.
  9. Asus ROG G752V Fan Replacement: paso 9, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 9, imagen 2 de 2
    • Slowly pull out the keyboard while lifting it about an inch.
    • There are cables attached to the keyboard and motherboard. DO NOT lift it more than 2 inches above the laptop.
  10. Asus ROG G752V Fan Replacement: paso 10, imagen 1 de 3 Asus ROG G752V Fan Replacement: paso 10, imagen 2 de 3 Asus ROG G752V Fan Replacement: paso 10, imagen 3 de 3
    • Using an ESD safe tool, detach all 3 ribbon cables securing the keyboard to the laptop.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
  11. Asus ROG G752V Fan Replacement: paso 11, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 11, imagen 2 de 2
    • Once the cables are detached, lift the keyboard about 2 inches up and remove it from the rest of the body.
    • Make sure that the screen is open like the photo. This will ensure that none your laptop components will not be bent.
  12. Asus ROG G752V Fan Replacement: paso 12, imagen 1 de 3 Asus ROG G752V Fan Replacement: paso 12, imagen 2 de 3 Asus ROG G752V Fan Replacement: paso 12, imagen 3 de 3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the left of the socket.
    • Pull parallel to the motherboard, not straight up.
  13. Asus ROG G752V Fan Replacement: paso 13, imagen 1 de 3 Asus ROG G752V Fan Replacement: paso 13, imagen 2 de 3 Asus ROG G752V Fan Replacement: paso 13, imagen 3 de 3
    • Remove two 5.8 mm screws holding the screen and the laptop located at the hinge.
    • This will unlatch the screen from the laptop entirely.
    • Remove the screen.
  14. Asus ROG G752V Fan Replacement: paso 14, imagen 1 de 1
    • Remove the four 5.8 mm screws securing the battery to the laptop.
  15. Asus ROG G752V Fan Replacement: paso 15, imagen 1 de 1
    • Use your hands to remove the battery.
    • If you're having trouble, push down on the black plastic on the screen side of the battery. This should release the battery.
  16. Asus ROG G752V Fan Replacement, Fan: paso 16, imagen 1 de 2 Asus ROG G752V Fan Replacement, Fan: paso 16, imagen 2 de 2
    • Unplug the fan-motherboard connection cable.
  17. Asus ROG G752V Fan Replacement: paso 17, imagen 1 de 3 Asus ROG G752V Fan Replacement: paso 17, imagen 2 de 3 Asus ROG G752V Fan Replacement: paso 17, imagen 3 de 3
    • Unscrew and remove the three 5.8mm screws on the small circuit board to the right of the right side fan with a Phillips #00 screwdriver.
    • Lift up the small circuit board covering the fan and put it aside.
  18. Asus ROG G752V Fan Replacement: paso 18, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 18, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the three 5.2 mm screws that connect the fan to the motherboard.
  19. Asus ROG G752V Fan Replacement: paso 19, imagen 1 de 1
    • With your hands, slowly and carefully lift up the right side fan.
  20. Asus ROG G752V Fan Replacement: paso 20, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 20, imagen 2 de 2
    • Carefully unlatch the left side fan cable from the motherboard.
  21. Asus ROG G752V Fan Replacement: paso 21, imagen 1 de 3 Asus ROG G752V Fan Replacement: paso 21, imagen 2 de 3 Asus ROG G752V Fan Replacement: paso 21, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove the two 5.8mm screws that connect the left fan to the motherboard.
  22. Asus ROG G752V Fan Replacement: paso 22, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 22, imagen 2 de 2
    • With your hands, carefully lift the left fan and unlatch the fan from the motherboard.
Conclusión
4 personas más completaron esta guía.
Un comentario
Awesome! Epic guide thank you!
Citizen Gone - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 39
Todo El Tiempo: 2,558
