Saltar al contenido principal
Asus R510CA-OB01 Motherboard Replacement
Qué necesitas
  1. Asus R510CA-OB01 Motherboard Replacement, Keyboard and Mousepad: paso 1, imagen 1 de 1
    • Shut down the computer and disconnect all external devices connected to it.
    • Turn the computers that it is upside down. Position the computer with the front towards you.
  2. Asus R510CA-OB01 Motherboard Replacement: paso 2, imagen 1 de 1
    • After detaching the battery, remove the two 5mm screws holding down the casing using a Phillips #00 screwdriver.
  3. Asus R510CA-OB01 Motherboard Replacement: paso 3, imagen 1 de 2 Asus R510CA-OB01 Motherboard Replacement: paso 3, imagen 2 de 2
    • Loosen the four 12mm screws on the bottom and top panel of your device using a Phillips #0 screwdriver.
  4. Asus R510CA-OB01 Motherboard Replacement: paso 4, imagen 1 de 3 Asus R510CA-OB01 Motherboard Replacement: paso 4, imagen 2 de 3 Asus R510CA-OB01 Motherboard Replacement: paso 4, imagen 3 de 3
    • Use the grips to slide the panel off.
    • Remove the panel by lifting it off the device.
  5. Asus R510CA-OB01 Motherboard Replacement: paso 5, imagen 1 de 2 Asus R510CA-OB01 Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove the three 5mm screws holding down the hard drive and the five 5mm screws holding down the casing using a Phillips #00 bit.
  6. Asus R510CA-OB01 Motherboard Replacement: paso 6, imagen 1 de 2 Asus R510CA-OB01 Motherboard Replacement: paso 6, imagen 2 de 2
    • Turn the laptop the right way up and face it towards you.
    • Insert the flat edge of the flat plastic opening tool into the crease of the keyboard cover.
    • While the opening tool is in the crease, carefully pry open the casing by sliding the plastic opening tool along the edge.
  7. Asus R510CA-OB01 Motherboard Replacement: paso 7, imagen 1 de 2 Asus R510CA-OB01 Motherboard Replacement: paso 7, imagen 2 de 2
    • Make sure that the entire cover has been released front the plastic pins.
    • Slowly lift the cover open from the front of the laptop but do not completely remove.
    • Note the three locations of the three white and blue data cables connecting the keyboard to the computer's main board.
  8. Asus R510CA-OB01 Motherboard Replacement: paso 8, imagen 1 de 3 Asus R510CA-OB01 Motherboard Replacement: paso 8, imagen 2 de 3 Asus R510CA-OB01 Motherboard Replacement: paso 8, imagen 3 de 3
    • Remove each data cable from the motherboard by using your finger or the plastic opening tool to lift the white latch.
    • The cable will slide out of its place.
  9. Asus R510CA-OB01 Motherboard Replacement: paso 9, imagen 1 de 2 Asus R510CA-OB01 Motherboard Replacement: paso 9, imagen 2 de 2
    • With the data cables removed and the keyboard module fully disconnected, the keyboard module should come free from the laptop.
  10. Asus R510CA-OB01 Motherboard Replacement, Optical Drive: paso 10, imagen 1 de 2 Asus R510CA-OB01 Motherboard Replacement, Optical Drive: paso 10, imagen 2 de 2
    • Remove the 4.5mm silver screw in the top right corner using a Phillips #0 bit.
    • Remove the three 2mm silver screws using a Phillips #000 bit.
    • Remove the 5mm screw using a Phillips #1 bit that is holding the optical drive in place.
    • With your hands, gently slide the optical drive out of the laptop.
  11. Asus R510CA-OB01 Motherboard Replacement, Motherboard: paso 11, imagen 1 de 1
    • Remove the seven 5mm screws that are holding both the fan and motherboard in place using a Phillips #1 bit.
  12. Asus R510CA-OB01 Motherboard Replacement: paso 12, imagen 1 de 3 Asus R510CA-OB01 Motherboard Replacement: paso 12, imagen 2 de 3 Asus R510CA-OB01 Motherboard Replacement: paso 12, imagen 3 de 3
    • Disconnect the cables from the motherboard by sliding the cable out of place.
    • Disconnect the cables connecting the fan to the motherboard and laptop by pulling the cable out of place.
  13. Asus R510CA-OB01 Motherboard Replacement: paso 13, imagen 1 de 2 Asus R510CA-OB01 Motherboard Replacement: paso 13, imagen 2 de 2
    • Lift the motherboard on the right side so that it is lifted slightly above the hard drive.
    • Slide the motherboard and fan to the right. Both components should be free from the device.
    • Once the fan and motherboard are free from the device, flip them over and remove the cable connecting both components.
  14. Asus R510CA-OB01 Motherboard Replacement: paso 14, imagen 1 de 2 Asus R510CA-OB01 Motherboard Replacement: paso 14, imagen 2 de 2
    • Remove the four 5mm screws connecting the fan and motherboard using a Phillips #1 bit.
    • Once the screws have been removed, the fan and motherboard should come apart.
  15. Asus R510CA-OB01 Motherboard Replacement: paso 15, imagen 1 de 1
    • The motherboard should now be free from the device .
Conclusión
Una persona más ha completado esta guía.
Mame
Miembro Desde 03/25/19
13 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G2, Henning Spring 2019 Miembro de IUPUI, Team S1-G2, Henning Spring 2019
IUPUI-HENNING-S19S1G2
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 603
