Saltar al contenido principal
Asus Q524U Fan Assembly Replacement
Qué necesitas
  1. Asus Q524U Fan Assembly Replacement, Back Panel: paso 1, imagen 1 de 2 Asus Q524U Fan Assembly Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove ten 3 mm screws using a Phillips #0 screwdriver.
  2. Asus Q524U Fan Assembly Replacement: paso 2, imagen 1 de 1
    • Lift up the back panel and set it to the side.
  3. Asus Q524U Fan Assembly Replacement, Battery: paso 3, imagen 1 de 2 Asus Q524U Fan Assembly Replacement, Battery: paso 3, imagen 2 de 2
    • Using your fingers, grip onto both sides of the wire harness and push it upwards.
  4. Asus Q524U Fan Assembly Replacement: paso 4, imagen 1 de 2 Asus Q524U Fan Assembly Replacement: paso 4, imagen 2 de 2
    • Remove the five 3 mm screws holding the battery in place using a Phillips #0 screwdriver.
  5. Asus Q524U Fan Assembly Replacement: paso 5, imagen 1 de 3 Asus Q524U Fan Assembly Replacement: paso 5, imagen 2 de 3 Asus Q524U Fan Assembly Replacement: paso 5, imagen 3 de 3
    • Tilt the small black tab up which will allow the blue tape to be slid out.
  6. Asus Q524U Fan Assembly Replacement: paso 6, imagen 1 de 1
    • Simply lift the battery up and out of its holding area.
  7. Asus Q524U Fan Assembly Replacement, Fan Assembly: paso 7, imagen 1 de 1
    • Remove the four 3 mm screws holding the fan in place using a Phillips #0 screwdriver.
  8. Asus Q524U Fan Assembly Replacement: paso 8, imagen 1 de 2 Asus Q524U Fan Assembly Replacement: paso 8, imagen 2 de 2
    • Remove five 3 mm screws holding the heat sink in place using a Phillips #0 screwdriver.
  9. Asus Q524U Fan Assembly Replacement: paso 9, imagen 1 de 3 Asus Q524U Fan Assembly Replacement: paso 9, imagen 2 de 3 Asus Q524U Fan Assembly Replacement: paso 9, imagen 3 de 3
    • Pull up fan connector tab by using the plastic handle.
  10. Asus Q524U Fan Assembly Replacement: paso 10, imagen 1 de 2 Asus Q524U Fan Assembly Replacement: paso 10, imagen 2 de 2
    • Unwind the cable wrapped around the fan casing.
  11. Asus Q524U Fan Assembly Replacement: paso 11, imagen 1 de 1
    • Disconnect the small cable from the fan.
  12. Asus Q524U Fan Assembly Replacement: paso 12, imagen 1 de 1
    • After all screws and cables are unsecured, lift the fan assembly out of the laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 15
Todo El Tiempo: 102
