Saltar al contenido principal
Asus Padfone 2 Camera Replacement
Qué necesitas
  1. Asus Padfone 2 Camera  Replacement, Power Down Device: paso 1, imagen 1 de 1
    • Hold down the power button.
  2. Asus Padfone 2 Camera  Replacement, Remove Back Plate: paso 2, imagen 1 de 3 Asus Padfone 2 Camera  Replacement, Remove Back Plate: paso 2, imagen 2 de 3 Asus Padfone 2 Camera  Replacement, Remove Back Plate: paso 2, imagen 3 de 3
    • Use plastic opening tool to pry off the back cover of the phone.
  3. Asus Padfone 2 Camera  Replacement, Battery Removal: paso 3, imagen 1 de 3 Asus Padfone 2 Camera  Replacement, Battery Removal: paso 3, imagen 2 de 3 Asus Padfone 2 Camera  Replacement, Battery Removal: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
    • Disconnect battery connecting cord using tweezers.
  4. Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: paso 4, imagen 1 de 3 Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: paso 4, imagen 2 de 3 Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: paso 4, imagen 3 de 3
    • Use T5 Torx screwdriver to remove 14 screws from internal back plate.
    • Use of magnetic pad will help with keeping track of screws.
    • Once screws are out, remove the plate.
  5. Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: paso 5, imagen 1 de 3 Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: paso 5, imagen 2 de 3 Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: paso 5, imagen 3 de 3
    • Disconnect four plugs to the motherboard using tweezers.
    • Lift up green motherboard.
  6. Asus Padfone 2 Camera  Replacement, Removing Camera: paso 6, imagen 1 de 2 Asus Padfone 2 Camera  Replacement, Removing Camera: paso 6, imagen 2 de 2
    • Remove camera from back of the motherboard with tweezers.
Conclusión
3 personas más completaron esta guía.
Erica
Miembro Desde 09/25/14
473 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 5-4, Mcgee Fall 2014 Miembro de USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
Miembros de 4
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 2,010
