Qué necesitas
Herramienta utilizada en este paso:Tweezers$4.99
Remove the warning sticker that covers the battery plug and connecting cord.
Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
Disconnect battery connecting cord using tweezers.
Use T5 Torx screwdriver to remove 14 screws from internal back plate.
Once screws are out, remove the plate.
Disconnect four plugs to the motherboard using tweezers.
Lift up green motherboard.
3 personas más completaron esta guía.
