Saltar al contenido principal
Asus K55a-si50301p Battery Replacement
  1. Asus K55a-si50301p Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p Battery Replacement: paso 2, imagen 1 de 1
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p Battery Replacement: paso 3, imagen 1 de 1
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 658
