Saltar al contenido principal
Asus Chromebook Flip C302CA Wi-Fi Card Replacement
Qué necesitas
  1. Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Back Panel: paso 1, imagen 1 de 1
    • Turn the laptop over so the bottom is facing you.
  2. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: paso 2, imagen 1 de 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: paso 2, imagen 2 de 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: paso 2, imagen 3 de 3
    • Remove two rubber caps on the top.
    • Remove the two 1 mm screws using the Phillips #00 screwdriver.
  3. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: paso 3, imagen 1 de 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: paso 3, imagen 2 de 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: paso 3, imagen 3 de 3
    • Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
    • Carefully remove the back panel using an opening pick.
  4. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: paso 4, imagen 1 de 2 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: paso 4, imagen 2 de 2
    • Remove the back panel from the laptop.
  5. Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Battery: paso 5, imagen 1 de 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Battery: paso 5, imagen 2 de 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Battery: paso 5, imagen 3 de 3
    • Remove the sticker holding the cable using a pair of tweezers.
    • Detach the cable from the motherboard by lifting it up with a spudger.
    • Always use a plastic or nylon ESD-safe tool. Metal spudger and other sharp tools can puncture a battery, potentially causing a fire.
  6. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: paso 6, imagen 1 de 2 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: paso 6, imagen 2 de 2
    • Remove the two 2 mm screws holding the battery using a Phillips #00 screwdriver.
  7. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: paso 7, imagen 1 de 1
    • Carefully lift up the battery from the front side to remove it from the laptop.
  8. Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Wi-Fi Card: paso 8, imagen 1 de 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Wi-Fi Card: paso 8, imagen 2 de 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Wi-Fi Card: paso 8, imagen 3 de 3
    • Carefully remove the black and white cables connected to the Wi-Fi card.
    • Remove the single 2 mm screw while holding the Wi-Fi card using the Phillips #00 screwdriver.
    • Remove the Wi-Fi card from the laptop.
Conclusión
Zahid Enriquez
Miembro Desde 02/08/22
543 Reputación
4 Guías creadas
Equipo
Gateway, Team 1-2, Saknee Spring 2022 Miembro de Gateway, Team 1-2, Saknee Spring 2022
GCC-SAKNEE-S22S1G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 367
