Saltar al contenido principal
Asus Chromebook C300SA-DS02 Motherboard Replacement
Qué necesitas
  1. Asus Chromebook C300SA-DS02 Motherboard Replacement, Keyboard: paso 1, imagen 1 de 2 Asus Chromebook C300SA-DS02 Motherboard Replacement, Keyboard: paso 1, imagen 2 de 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 2, imagen 1 de 3 Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 2, imagen 2 de 3 Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 2, imagen 3 de 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 3, imagen 1 de 3 Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 3, imagen 2 de 3 Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 3, imagen 3 de 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 Motherboard Replacement, Battery: paso 5, imagen 1 de 2 Asus Chromebook C300SA-DS02 Motherboard Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 6, imagen 1 de 2 Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 6, imagen 2 de 2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 7, imagen 1 de 1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 Motherboard Replacement, Display Assembly: paso 8, imagen 1 de 2 Asus Chromebook C300SA-DS02 Motherboard Replacement, Display Assembly: paso 8, imagen 2 de 2
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 9, imagen 1 de 1
    • Peel back the tape covering the display cable.
    • Ease the cable towards the screen and out from the connector.
  10. Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 10, imagen 1 de 1
    • Use a Phillips #0 driver to remove the six 5mm screws on the top right and left display hinges.
  11. Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 11, imagen 1 de 1
    • Gently lift the display assembly up and away from the laptop.
  12. Asus Chromebook C300SA-DS02 Motherboard Replacement, WiFi Card: paso 12, imagen 1 de 3 Asus Chromebook C300SA-DS02 Motherboard Replacement, WiFi Card: paso 12, imagen 2 de 3 Asus Chromebook C300SA-DS02 Motherboard Replacement, WiFi Card: paso 12, imagen 3 de 3
    • Use the spudger to pop the black and white coaxial WiFi cables up from the WiFi card.
  13. Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 13, imagen 1 de 2 Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 13, imagen 2 de 2
    • Remove the one 3.6mm Phillips #0 screw from the WiFi card.
    • Pull and lift the WiFi card away from the motherboard.
  14. Asus Chromebook C300SA-DS02 Motherboard Replacement, Motherboard: paso 14, imagen 1 de 3 Asus Chromebook C300SA-DS02 Motherboard Replacement, Motherboard: paso 14, imagen 2 de 3 Asus Chromebook C300SA-DS02 Motherboard Replacement, Motherboard: paso 14, imagen 3 de 3
    • Using your Phillips #0 screwdriver, unscrew three, 3.6mm screws from the silver heatsink.
    • Remove the heatsink from the motherboard.
  15. Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 15, imagen 1 de 2 Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 15, imagen 2 de 2
    • Remove the black tape from the motherboard covering the 4.2mm silver flat screw.
    • Using a Phillips #0 screwdriver, remove the 4.4mm screw on the right and the 4.2mm silver flat screw on the left from the motherboard.
    • This is a used device so the screws may be different than the original Chromebook.
  16. Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 16, imagen 1 de 3 Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 16, imagen 2 de 3 Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 16, imagen 3 de 3
    • Using the black nylon spudger, unlock the black bar on the ZIF connector attached to the mid-right of the motherboard.
    • Remove the ribbon cable that attaches the motherboard to the daughterboard.
  17. Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 17, imagen 1 de 2 Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 17, imagen 2 de 2
    • Using the black nylon spudger, carefully slide the speaker cable connector out from its attachment on the motherboard.
  18. Asus Chromebook C300SA-DS02 Motherboard Replacement: paso 18, imagen 1 de 1
    • Wiggle and pull the motherboard out from the bottom case.
Conclusión
Sarah Westberg
Miembro Desde 03/11/19
29,489 Reputación
71 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 118
19,537 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 419
