Introducción
If your Arlo Ultra 2 speaker is non-functional or broken, you may wish to replace it using this guide. The camera speaker enables two-way conversation and siren capability. If it is non functioning, when talking through the speaker or when playing the siren, the sound may sound distorted or inaudible. If the speaker is disconnected, visit the troubleshooting page.
Qué necesitas
Press the button on the bottom of the camera to release the case.
Pull the white case off of camera.
Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity. They are found in each corner.
Use the tip of a spudger or your fingernail to flip up the small locking flap on each ZIF connector. Then, you can safely pull the cables out.
Una persona más ha completado esta guía.
