Saltar al contenido principal
Arlo Ultra 2 Speaker Replacement
Qué necesitas
  1. Arlo Ultra 2 Speaker Replacement, Battery: paso 1, imagen 1 de 2 Arlo Ultra 2 Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Press the button on the bottom of the camera to release the case.
    • Pull the white case off of camera.
  2. Arlo Ultra 2 Speaker Replacement: paso 2, imagen 1 de 1
    • Pull the white cube shaped battery from the back to remove it from camera.
  3. Arlo Ultra 2 Speaker Replacement, Speaker: paso 3, imagen 1 de 2 Arlo Ultra 2 Speaker Replacement, Speaker: paso 3, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity. They are found in each corner.
  4. Arlo Ultra 2 Speaker Replacement: paso 4, imagen 1 de 2 Arlo Ultra 2 Speaker Replacement: paso 4, imagen 2 de 2
    • Using the spudger, loosen and remove the camera faceplate.
  5. Arlo Ultra 2 Speaker Replacement: paso 5, imagen 1 de 2 Arlo Ultra 2 Speaker Replacement: paso 5, imagen 2 de 2
    • Using the spudger, loosen and remove the back casing to expose the camera hardware.
  6. Arlo Ultra 2 Speaker Replacement: paso 6, imagen 1 de 2 Arlo Ultra 2 Speaker Replacement: paso 6, imagen 2 de 2
    • Very gently, pry the circuit boards apart from the white connector, removing the upper circuit board.
  7. Arlo Ultra 2 Speaker Replacement: paso 7, imagen 1 de 2 Arlo Ultra 2 Speaker Replacement: paso 7, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove two 5.0 mm screws from the metal bracket.
    • Use a spudger to separate the long metal bracket.
    • There is an arrow etched into the bracket. It points towards the top of the camera. This is important when reassembling the camera.
  8. Arlo Ultra 2 Speaker Replacement: paso 8, imagen 1 de 3 Arlo Ultra 2 Speaker Replacement: paso 8, imagen 2 de 3 Arlo Ultra 2 Speaker Replacement: paso 8, imagen 3 de 3
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each ZIF connector. Then, you can safely pull the cables out.
    • Be sure to pry up on the hinged flap, not the connector socket.
  9. Arlo Ultra 2 Speaker Replacement: paso 9, imagen 1 de 2 Arlo Ultra 2 Speaker Replacement: paso 9, imagen 2 de 2
    • Use a spudger to carefully push on each side of the speaker cable connector until it's out of its socket.
  10. Arlo Ultra 2 Speaker Replacement: paso 10, imagen 1 de 1
    • Remove the small green circuit board.
  11. Arlo Ultra 2 Speaker Replacement: paso 11, imagen 1 de 3 Arlo Ultra 2 Speaker Replacement: paso 11, imagen 2 de 3 Arlo Ultra 2 Speaker Replacement: paso 11, imagen 3 de 3
    • Feed the speaker cable through the opening to remove the speaker.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 121
