Saltar al contenido principal
Arlo Pro 2 Base Station Motherboard Replacement
Qué necesitas
  1. Arlo Pro 2 Base Station Motherboard Replacement, Base Station Motherboard: paso 1, imagen 1 de 3 Arlo Pro 2 Base Station Motherboard Replacement, Base Station Motherboard: paso 1, imagen 2 de 3 Arlo Pro 2 Base Station Motherboard Replacement, Base Station Motherboard: paso 1, imagen 3 de 3
    • Use a TR10 Torx screwdriver to remove the two 10 mm screws on the side of the base station, above the USB ports.
    • Pull apart the top case from the bottom.
    • This may require some force as there are internal catches.
  2. Arlo Pro 2 Base Station Motherboard Replacement: paso 2, imagen 1 de 3 Arlo Pro 2 Base Station Motherboard Replacement: paso 2, imagen 2 de 3 Arlo Pro 2 Base Station Motherboard Replacement: paso 2, imagen 3 de 3
    • Use a TR10 Torx screwdriver to remove the two 10 mm screws to disconnect the motherboard from the base casing.
    • The motherboard is connected to the USB ports; when removing it be careful to gently remove the USB ports from their cavities to avoid any damage.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ben I.
Miembro Desde 03/26/25
493 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 2-2, Botvin Spring 2025 Miembro de UMass Dartmouth, Team 2-2, Botvin Spring 2025
UMASSD-BOTVIN-S25S2G2
Miembros de 3
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 100
