Saltar al contenido principal
Anker SoundCore 2 Speaker Replacement
Qué necesitas
  1. Anker SoundCore 2 Speaker Replacement, Front Panel: paso 1, imagen 1 de 2 Anker SoundCore 2 Speaker Replacement, Front Panel: paso 1, imagen 2 de 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Speaker Replacement, Speaker: paso 2, imagen 1 de 3 Anker SoundCore 2 Speaker Replacement, Speaker: paso 2, imagen 2 de 3 Anker SoundCore 2 Speaker Replacement, Speaker: paso 2, imagen 3 de 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Speaker Replacement: paso 3, imagen 1 de 3 Anker SoundCore 2 Speaker Replacement: paso 3, imagen 2 de 3 Anker SoundCore 2 Speaker Replacement: paso 3, imagen 3 de 3
    • The speakers do not use wires so when replacing the speaker, make sure you align the metal prongs with the metal clips on the motherboard.
Conclusión
Una persona más ha completado esta guía.
9 comentarios
Excellent guide, my speaker falls to the ground, and one of two speaker stops working, disassemble and verifying, was the speaker clip was loose
Renato Galindo - Contestar
Where can I buy a speaker for the repair ? Or will any sized speaker work ?
philcuchetti - Contestar
hi, did you manage to buy a replacement speaker? If yes from where pls?
jafarez -
Do someone get a new speaker? I need to buy one!
everton.euclides - Contestar
jafarez -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 32
Ultimos 30 días: 121
Todo El Tiempo: 4,143
