Introducción
This is a step by step guide to replace the battery in the Anker SoundCore 2.
Before replacing anything, be sure to take a look at the troubleshooting page for this device.
Qué necesitas
Insert a spudger between the front panel and the body of the speaker.
Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
Use your hand to remove the speakers.
2 personas más completaron esta guía.
5 comentarios
It would be nice to have the specifications of the battery so availability can be checked before disassembly.
Hey I had a question.So i kind of dipped anker sound core 2 in water eithout the charging cover on and now it wont turn on.Can you Help what might be the problem here?
Kapazität 2600 mAh Leistung 19.24 Wh Spannung 7.4 V Typ Li-ion
Habe ihn mir mit 2 18650/3500mA Akkus von Temu selber gebaut. Lädt zwar jetzt länger und hält aber auch 20% länger. Dabei aufpassen und die Kabel an den Akkus wieder richtig anlöten. Wegen der Li-Ionen Ladeautomatik auf der Hauptplatine. Am Ende in einen passenden Schrumpfschlauch stecken und aufpassen das rundum kein Kurzschluss passieren kann.
