Saltar al contenido principal
Anker 2.4G Wireless Mouse Battery Replacement
Qué necesitas
  1. Anker 2.4G Wireless Mouse Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the battery cover with a plastic opening tool, nylon spudger, or a fingernail.
  2. Anker 2.4G Wireless Mouse Battery Replacement: paso 2, imagen 1 de 1
    • Remove the battery with a finger nail or a nonmetal tool.
Conclusión
Una persona más ha completado esta guía.
Vincent Lee
Miembro Desde 01/23/14
361 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 1-39, Maness Winter 2014 Miembro de Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Miembros
16 Guías creadas
2 comentarios
My Anker vertical wireless mouse uses 2 "AAA" batteries. It is Model TMI56G. Batteries are fresh. Dongle is new. The mouse worked fine with the dongle that was broken prior to the company sending me a replacement. The highest bar on the thumb side on the mouse comes on and glows red briefly when I turn the mouse on. There is no clear button on top of the mouse. I have Windows 10 and when I check my settings I keep getting an "ERROR CODE 10" FOR MY ANKER Mouse. My LOGITECH mouse works just fine when I plug into the same USB port. Could I have been sent the wrong dongle for my ANKER Mouse? Please advise.
Thank You,
Richard Johnson
mutantear@comcast.net
Rick Johnson - Contestar
Any help would be appreciated. I need to return the LOGTECH mouse I'm now using to it's owner.
Thanks,
Rick
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 5,603
