Saltar al contenido principal
Amazon Kindle DX Previous Page Key Replacement
Qué necesitas
  1. Amazon Kindle DX Previous Page Key Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the Kindle so the back is facing upwards.
  2. Amazon Kindle DX Previous Page Key Replacement: paso 2, imagen 1 de 1
    • Push an opening tool against the bottom cover edge of the device. Move the tool's edge around the bottom plastic piece to pop it open.
  3. Amazon Kindle DX Previous Page Key Replacement: paso 3, imagen 1 de 1
    • Remove the plastic piece.
  4. Amazon Kindle DX Previous Page Key Replacement: paso 4, imagen 1 de 2 Amazon Kindle DX Previous Page Key Replacement: paso 4, imagen 2 de 2
    • Remove two 40 mm screws (one on each corner) using a Phillips #00 screwdriver.
  5. Amazon Kindle DX Previous Page Key Replacement: paso 5, imagen 1 de 2 Amazon Kindle DX Previous Page Key Replacement: paso 5, imagen 2 de 2
    • Use the edges of the opening tool, get in between the seams of the front and back panel, and use the tool to separate the pieces. Once loose, lift back panel off of the device.
  6. Amazon Kindle DX Previous Page Key Replacement: paso 6, imagen 1 de 2 Amazon Kindle DX Previous Page Key Replacement: paso 6, imagen 2 de 2
    • Remove two 30 mm screws securing the battery with a Phillips #00 screwdriver.
  7. Amazon Kindle DX Previous Page Key Replacement: paso 7, imagen 1 de 2 Amazon Kindle DX Previous Page Key Replacement: paso 7, imagen 2 de 2
    • Remove the battery from the device.
  8. Amazon Kindle DX Previous Page Key Replacement, Previous Page Key: paso 8, imagen 1 de 3 Amazon Kindle DX Previous Page Key Replacement, Previous Page Key: paso 8, imagen 2 de 3 Amazon Kindle DX Previous Page Key Replacement, Previous Page Key: paso 8, imagen 3 de 3
    • Remove five 30 mm screws from the midframe using a Phillips #000 screwdriver.
  9. Amazon Kindle DX Previous Page Key Replacement: paso 9, imagen 1 de 1
    • Remove the midframe to reveal the motherboard.
  10. Amazon Kindle DX Previous Page Key Replacement: paso 10, imagen 1 de 2 Amazon Kindle DX Previous Page Key Replacement: paso 10, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the "previous page" button from the side function keys using a pair of tweezers.
Conclusión
Lori White
Miembro Desde 09/28/16
557 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 1-5, Cagle Fall 2016 Miembro de USF Tampa, Team 1-5, Cagle Fall 2016
USFT-CAGLE-F16S1G5
3 Miembros
8 Guías creadas
2 comentarios
The title says “keyboard”, this is button replacement…………….
Robert Clayworth - Contestar
The title says “keyboard” replacement. This is button replacement…………….
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 1,181
