Introducción
Before you begin, make sure the device is off. You will need to use the screen replacement guide as a prerequisite.
Qué necesitas
Locate the power cable that links the battery to the motherboard.
Carefully unplug the battery power cable to disconnect the battery from the motherboard.
11 personas más completaron esta guía.
9Guía Comentarios
I’m confused. If it’s a battery replacement issue, why is the battery not listed on the parts list? Is that not necessary once you take the old one out? Where do I get a new battery to replace the one this is teaching me to remove? O.o
How do you know if ita battery or charging port? Mine dont do anything whe. Its
