Saltar al contenido principal
Amazon Echo Show 10 3rd Gen Woofer Replacement
Qué necesitas
  1. Amazon Echo Show 10 3rd Gen Woofer Replacement, Woofer: paso 1, imagen 1 de 2 Amazon Echo Show 10 3rd Gen Woofer Replacement, Woofer: paso 1, imagen 2 de 2
    • With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
    • Remove the lid and set it aside.
  2. Amazon Echo Show 10 3rd Gen Woofer Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #2 screwdriver to remove the six 13 mm screws along the perimeter of the speaker.
  3. Amazon Echo Show 10 3rd Gen Woofer Replacement: paso 3, imagen 1 de 2 Amazon Echo Show 10 3rd Gen Woofer Replacement: paso 3, imagen 2 de 2
    • Use an opening tool to pry up along the edge of the speaker.
    • Gently lift the woofer out of the device.
    • The woofer is connected to a cable so don't yank it out or you will damage the connector.
  4. Amazon Echo Show 10 3rd Gen Woofer Replacement: paso 4, imagen 1 de 1
    • Tilt the woofer so the side with the cables is angled upwards.
    • Desolder the three separate cable connectors from the woofer attached to the plate using a soldering iron.
    • For information on soldering, refer to the How to Solder and Desolder Connections guide.
  5. Amazon Echo Show 10 3rd Gen Woofer Replacement: paso 5, imagen 1 de 1
    • After desoldering the three cables, lift the woofer out of the shell of the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 79
