Introducción
This guide will walk you through the basic replacement process for the two speaker tweeters found within your Amazon Echo Show 10 3rd Gen device. These tweeters are responsible for the output of upper-range sounds (also known as "treble"), and may need replacement if not functioning properly. The malfunctioning of this component can be seen through distorted audio or the complete absence of sound.
Make sure other solutions found within the Amazon Echo Show 10 3rd Gen troubleshooting page (such as unmuting your Echo or toggling 'Do Not Disturb' off) have been attempted before committing to disassembly and replacement.
Before you begin, make sure to turn off the device.
Qué necesitas
With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
Remove the lid and set it aside.
